GARRY_AND_SUSIE
Message 1 of 3
Just testing as having problems on lithium forums with new lines from ipad2
Carriage return Carriage return
HTML code for car. Ret
car ret.
end
OK I've proved I can't get a new line it to work on an iPad 2 when posting. Unless I use the native HTML code of " < B R >" but in lowercase and without the " and spaces. Can anyone help?
2 REPLIES 2
Message 2 of 3
Re: Just testing as having problems on lithium forums with new lines from ipad2
This issue was raised by one of the community leaders stuartrogerson
The answer from KerryG, was as follows:-
aha - I think I can shed some more light on this... seems that the rich text editor is not supported for the iPad so you will need to use HTML to get your paragraph and line breaks i'm afraid."
I will ask Stuart to comment here, on the outcome.
Distinguished Guru
Message 3 of 3
I'm afraid the forum doesn't like iPads a problem with Apple itself not providing the necessaries for rtf editing. HTML only partially works in that < p > and br give the results a simple line break. You don't need to go into the HTML option to do it either as inserting a break
in the rtf editor makes it work as well. A pain however you look it?!
the lithium team are aware of the problem but so far have not been able to do anything for us.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
