Distinguished Guru
Message 1 of 46
Kerry re the forum
I have terrible problems using this forum with my iPad my main access as it will not accept the return key as para break but runs everything together even though it looks fine before I post can this be fixed? Four para breaks inserted.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
45 REPLIES 45
Message 2 of 46
Re: Kerry re the forum
Stuart, does the ipad have a control key?  maybe marked Ctrl
Keith
Distinguished Guru
Message 3 of 46
Keith
Nope nope
Helpful Post?
Message 4 of 46
Its just that the return key can sometimes send an old fashioned carriage return + linefeed, or carriage return only, or sometimes line feed only.
These can be simulated by control+M for carriage return, and control+J for line feed.
Is there no way to change the behaviour of the "return" button?
Distinguished Guru
Message 5 of 46
Nope Don't think so
Helpful Post?
Message 6 of 46
Have you tried shift+enter?
Distinguished Guru
Message 7 of 46
Yes yes
Helpful Post?
Message 8 of 46
@stuartrogerson wrote:
Yes yes
Does that mean it worked?
Distinguished Guru
Message 9 of 46
No it means it didn't :( Sadly
Helpful Post?
Message 10 of 46
No it means it didn't 😞 Sadly
Ahh well. What is missing is a line feed character I suspect. There must be an answer, cursor down maybe?
What an annoying problem, does it happen on the mobile version of the forum as well?
