Kazuyadog
Message 11 of 12
Re: LG Television is Slowing Broadband Speed.
WOW.
The TV is on,the internet is on,the phones all work,and i have gained some speed just tested it and its 14.79 mbps.
All from removing two wires from 3 and 4 on the extension,its amazing truly amazing.
If i could buy you a pint i really would.
Very Happy Chappy i am.
Will i need the powerline adaptors to run the TV wifi ?
imjolly
Message 12 of 12
If TV wifi is working ok then just leave it. If you find that streaming causes a problem then you can then consider powerline adapters which basically give you a wired connection instead of wireless
