Curtos
Message 1 of 13
LOS Light is red
Help!!
My internet just went down and when I went and checked the white box the LOS light is red and I don't know what to do?!?
Tags (1)
12 REPLIES 12
Keith_Beddoe
Message 2 of 13
Re: LOS Light is red
I assume that you are on FTTP?
LOS= Loss of signal.
Most likely a fibre fault somewhere, or possibly a fibre modem fault.
Make sure that the fibre going into the modem is not been bent or damaged, and that the connector has not come loose.
All you can do is to report it as a fault.
Curtos
Message 3 of 13
there is some yellow stuff between the wire going to the modem and the connector
Keith_Beddoe
Message 4 of 13
It would be best to arrange a visit from Openreach, via the FTTP fault number.
I am not sure whay you mean by "yellow stuff"
Message 5 of 13
I'd hope it was an ethernet cable. Smiley Very Happy
Curtos
Message 6 of 13
It's the one going to the optical input
Message 7 of 13
Right, not so familiar with FTTP, but I'd go with Keith's advice.
Keith_Beddoe
Message 8 of 13
Can you post a picture of it?
Anthony303
Message 9 of 13
hey Keith
i think that person you were talking to was talking about the small yellow cable that connects to the right side when looking behind the router.
my router also doesn't work by having that red light on the "LOS" bar.
i went all over the internet for help and the most helpful and common way to fix it is to get their services help. but im here to get help first.
licquorice
Message 10 of 13
You cannot fix it yourself, all you can do is report the fault.
