Message 1 of 9
Lack of bandwidth - Infinity not living up to promises
Hi
Watching SKY Sports on Android Tablet and tried to stick on the Olympic Golf on PC.
Both are working wirelessly within the house. The tablet has continuous streaming pictures to the football - no problems. The BBC Golf feed stuttered and eventually stopped, citing lack of bandwidth.
Now I thought Infinity was supposed to support multiple streaming devices (ha ha). Current connection details, with the tablet still running are:
Download speed: 7.61
Upload speed: 6.05
Ping Latency: 41.00
Running Further diagnostic
The browser esssion timed out - nice one (probably due to slow connection!)
Tried again, result:
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Ha ha - the results weren't shown above.
I'll try again but looks like Infinity isn't really living up to its promises (surprise, surprise)!
8 REPLIES 8
Message 2 of 9
Re: Lack of bandwidth - Infinity not living up to promises
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Message 3 of 9
Hi - thanks for the replay. Details are:
Message 4 of 9
Other check worked this time:
Message 5 of 9
Was that rest done with a wired or wireless connection?
Message 6 of 9
Both the PC and Tablet connect wirelessly, as was the test.
Message 7 of 9
You need to run the test with a wired connection to rule out wireless as being the problem first and foremost.
Message 8 of 9
Just by way of update, I recently met an ex-BT Engineer through a work query.
We discussed my poor Wi Fi experience and he basically advised that (BT) WiFi was never really intended to operate throughout houses / properties etc and really only works well on direct line of site. Any "angles" will affect the signal, deteriorating as you go along.
He did advise that, in order to obtain decent connection speeds upstairs, I convert to "Ethernet over power".
I have now purchased TP-Link AV500 nano units, plugged them in and achieve over 35mbs - that already 5x faster than the wireless connection.
I suppose it all goes back to my original statement - wireless is being sold as a fits all solution when it obviously isn't.
Message 9 of 9
and that is why no ISP will guarantee speed over wireless conenction
