stargazeruk2
Message 1 of 8
Lag spikes when playing games - wow and various xbox titles
Hoping someone on the forum is willing to give a helping hand as i have given up on BT callcentre where i only get taken through the same script every time and it is obvious that the person on the line have very limited if any technical skills other than reading back to me from their script.
I am connected through the Ottershaw exchange and getting estimated speed of 3 mb/s and when various speedtest i am normally between 1.8-2.7 mb/s
Actual downloadspeed is normally very much lower - recent BT speedtest shoved 599Kb/s but i have rarely seen actual speed over 400 kb/s
I wish i could try something that would give me faster broadband but Infinity is not going to come to my area soon...
my issue is that i randomly seem to be getting a big degradation in the service that makes it impossible to play any of the games the family likes to play - mostly World of Warcraft but also various Xbox titles.
It this point in time we have had problems for some three weeks and they only seem to get worse hence my attempt to get help through the forums.
The issue we have is that the speedtest seems ok, but the actual performance is awful with lagspikes and varying framerates in game that makes any play unbearable. Are there any solutions to this problem? I am using BT HomeHub 1.0 but connecting my computers (Mac's and Pc's) through a gigabit ethernet switch.
Grateful for any help
7 REPLIES 7
Message 2 of 8
Re: Lag spikes when playing games - wow and various xbox titles
there is a similar post here it looks like a server /network congestion outside the BT network this link may help
http://community.bt.com/t5/BB-Speed-Connection-Issues/High-Latency-on-World-of-Warcraft/td-p/463049
stargazeruk2
Message 3 of 8
In looking a little deeper at this a lot of the network data coming from the BT network is actually quite poor but there also seems to be issues in the US. The server i play on is based in Los Angeles and as i get into that area it seems to time out at a node 12.129.199.182...having said that i am not an expert in interpreting trace route logs... My DSL information below
Traceroute has started…
traceroute to 12.129.223.24 (12.129.223.24), 64 hops max, 72 byte packets
 1  api (192.168.1.254)  40.242 ms  99.496 ms  100.039 ms
 2  217.47.90.186 (217.47.90.186)  581.151 ms  479.674 ms  561.649 ms
 3  217.47.93.161 (217.47.93.161)  644.921 ms  640.764 ms  930.805 ms
 4  213.1.69.6 (213.1.69.6)  874.035 ms  720.611 ms  360.970 ms
 5  217.41.168.102 (217.41.168.102)  78.284 ms  84.132 ms  77.421 ms
 6  217.41.168.53 (217.41.168.53)  95.878 ms  495.249 ms  841.814 ms
 7  217.41.168.107 (217.41.168.107)  534.220 ms  294.464 ms  1087.315 ms
 8  acc1-10gige-0-2-0-4.l-far.21cn-ipp.bt.net (109.159.249.97)  1634.583 ms  1646.601 ms  1196.071 ms
 9  core1-te0-1-0-0.ealing.ukcore.bt.net (109.159.249.21)  1130.984 ms  1061.976 ms  1010.835 ms
10  transit2-xe1-0-0.ealing.ukcore.bt.net (62.6.200.134)  1242.866 ms  1188.524 ms  916.456 ms
11  t2c4-xe-9-3-0.uk-eal.eu.bt.net (166.49.168.61)  995.490 ms  1164.721 ms  912.039 ms
12  xe-8-0-0.edge4.london2.level3.net (212.187.192.61)  336.874 ms  266.250 ms  349.309 ms
13  ae-32-52.ebr2.london2.level3.net (4.68.117.62)  284.154 ms  213.475 ms  107.089 ms
14  ae-3-3.ebr1.london1.level3.net (4.69.141.189)  71.873 ms  68.585 ms  45.948 ms
15  vlan102.ebr2.london1.level3.net (4.69.143.90)  64.063 ms  69.918 ms  73.428 ms
16  ae-44-44.ebr1.newyork1.level3.net (4.69.137.78)  144.218 ms  119.203 ms  192.473 ms
17  ae-61-61.csw1.newyork1.level3.net (4.69.134.66)  158.046 ms  283.737 ms  216.817 ms
18  ae-1-60.edge3.newyork1.level3.net (4.69.155.17)  148.696 ms  149.499 ms  272.125 ms
19  att-level3.newyork1.level3.net (4.68.63.142)  470.914 ms  561.159 ms  661.554 ms
20  cr1.n54ny.ip.att.net (12.122.131.102)  708.952 ms  223.754 ms  217.297 ms
21  cr2.cgcil.ip.att.net (12.122.1.2)  206.538 ms  180.699 ms  217.932 ms
22  cr1.cgcil.ip.att.net (12.122.2.53)  221.267 ms  205.782 ms  537.644 ms
23  cr2.dvmco.ip.att.net (12.122.31.85)  331.367 ms  470.097 ms  228.070 ms
24  cr1.slkut.ip.att.net (12.122.30.25)  191.951 ms  212.701 ms  227.069 ms
25  cr2.la2ca.ip.att.net (12.122.30.30)  221.092 ms  241.495 ms  234.921 ms
26  gar29.la2ca.ip.att.net (12.122.129.241)  500.756 ms  291.832 ms  372.994 ms
27  12-122-254-238.attens.net (12.122.254.238)  310.214 ms
    12-122-254-234.attens.net (12.122.254.234)  606.889 ms  431.879 ms
28  mdf001c7613r0003-gig-12-1.lax1.attens.net (12.129.193.254)  598.710 ms  619.383 ms  552.863 ms
29  * * *
30  12.129.199.182 (12.129.199.182)  925.763 ms !X  1321.635 ms !X  1514.942 ms !X
DSL Connection
Link Information
Uptime:0 days, 3:18:07
Modulation:G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 2,656
Data Transferred (Sent/Received) [MB/MB]:29.61 / 161.14
Output Power (Up/Down) [dBm]:12.0 / 18.5
Line Attenuation (Up/Down) [dB]:30.0 / 50.0
SN Margin (Up/Down) [dB]:22.0 / 15.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 74,795
CRC Errors (Up/Down):0 / 9,173
HEC Errors (Up/Down):0 / 7,905
Line Profile:Interleaved
Message 4 of 8
how are you connecting to the hub wireless or wired
stargazeruk2
Message 5 of 8
100 Mbit Ethernet
Message 6 of 8
ok because your first hop is to your hub and that is typically <1ms
stargazeruk2
Message 7 of 8
I have run lots of traceroute and the first hop is never less than a MS. Tried rebooting both my switch and the homehub but no changes to the first hop. Varies between 2-90 MS. Does this indicate something? Most of my computers are relatively new as is the switch.
Message 8 of 8
I always get 1MS as do most people i know worth checking right through your network
