Hi guys
I changed from Talktalk to BT on Tues same landline number. When you ring the landline it says “not receiving incoming calls”. Have rang BT 3 times and still not sorted? Very frustrated. Any ideas? Thanks
Were you actually told that you could transfer your phone number to BT, as its not always the case?
Do you get the correct phone number when you dial 17070?
Have you ever been a BT customer before, at the same address?
Thanks Keith. Yeah it is the correct number when I ring17070 - seems only a few BT landline numbers can get through. No mobiles can get through and appears other networks
Then there is a porting issue, but that usually sorts itself out. How long ago was your service transferred?
@Weirman wrote:
Hi Keith - thanks for help. Changed from Talk Talk To BT on (Tues 13th Oct)
I would have hoped it would be sorted by now.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Please bear in mind that with the current crisis, it could take a long time for one of them to deal with your request.
Hi @Weirman welcome to the forum and sorry that you are not able to receive incoming calls. We'll be happy to help you get this fixed. I've sent you a Private Message with details on how to get in touch with the Mod team.
Cheers
John
