Johnoo
Expert
Message 1 of 6
Laptop will nmot connect to Network, Hub 6
I have a small Asus laptop that I mainly use for travel purposes, but weekly I update with Microsoft updates.
Recently it has failed to connect to my Hub6.
I can connect to BT WiFi X & BT Wifi FON but not to my HUB 6.
Then after connecting to BT X/FON is appears that the connection to the HUB 6 can be made.
Is there a known problem with HUB 6 in this respect?
Or any other suggestions welcome.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Laptop will nmot connect to Network, Hub 6
if you have already split the networks then try changing the mode from 1 to either 2 or 3 and see if that helps
Johnoo
Expert
Message 3 of 6
Re: Laptop will not connect to Network, Hub 6
Thanks for the idea, but unfortunately I don't know how to do this.
Does it mean changing Laptop or HUB?
imjolly
Message 4 of 6
go to advanced settings then wireless in hub and you will see set to mode 1  change to 2 or 3 and see if that helps
Johnoo
Expert
Message 5 of 6
Thanks for the tip, will give it a try
Keith_Beddoe
Message 6 of 6
A picture if it helps?
