lorddark
Message 11 of 25
Re: Laptop won't connect to internet through home hub
That doesn't work either 😞
Ethernet connection works fine.
gg30340
Message 12 of 25
Try setting up a different DNS server. Use the Google DNS settings.
Follow this guide again.
http://windows.microsoft.com/en-us/windows/change-tcp-ip-settings#1TC=windows-7
When you get to the part to specify DNS server.
Configure your network settings to use prefered 8.8.8.8 and alternate 8.8.4.4 as your DNS servers
lorddark
Message 13 of 25
Should I do this on the laptop or my main pc?
gg30340
Message 14 of 25
One other thing to check, when you are in the settings make sure that the IPv6 is unticked.
You should be doing it on your laptop that has the problem.
lorddark
Message 15 of 25
Would it be something to do with my IP address changing when I reset my home hub?
gg30340
Message 16 of 25
If it was a homehub IP problem your other devices would not connect to the Internet either nor would your laptop connect by Ethernet.
lorddark
Message 17 of 25
Changed dns to the google settings but that didn't work either Cat Mad
gg30340
Message 18 of 25
Did you check that IPv6 was unticked?
lorddark
Message 19 of 25
Yep I did although only on the laptop. Does it need to be unticked on the main pc too?
gg30340
Message 20 of 25
If all your other devices can connect to the Homehub by wireless and/or Ethernet and surf the Internet and your laptop can connect and surf by Ethernet it would rule out the hub being at fault.
As your laptop can connect by Ethernet but not wireless it would obviously point to a wireless problem on the laptop. I am out of ideas other than to suggest, unless somebody else can help, that the wireless network card on the laptop has developed a fault.
You could either get a new card fitted or probably a cheaper easier alternative would be to buy a wireless dongle and use that.
