lorddark
Message 21 of 25
Re: Laptop won't connect to internet through home hub
Ok, many thanks for your help 🙂
lorddark
Message 22 of 25
For a moment I thought I had solved it as the exlamation mark didn't appear and it seemed to be ok but it appeared again and the troubleshooter now says "Wireless Network Connection" doesn't have a valid IP configuration..
gg30340
Message 23 of 25
Go to Start > search  and type cmd > click on it to open a command prompt.
At the command prompt, copy and paste (or type) the following command and then press ENTER:
netsh int ip reset c:\resetlog.txt
Reboot the computer.
lorddark
Message 24 of 25
Thanks but I think I have sroted it. Comodo firewall semmed to be blocking svchost.exe for some reason, thus blocking internet access. I uninstalled it and installed zonealarm firewall instead and it seems to be ok now. Many thanks for your suggestions 🙂
gg30340
Message 25 of 25
Glad you have it working but I don't understand how the firewall was blocking wireless and not Ethernet connections.
