Message 1 of 50
Last 3 days broadband has been slow.
 The speed has decreased dramatically over the last 3 days.
I did a speedtest as instructed on here. Results.
Download speedachieved during the test was - 171 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :460 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
 IP Profile for your line is - 7000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 35.94:32.27:31.94 (SBE:NBE:smileytongue:BE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload speed achieved during the test was - 275 Kbps
 Upstream Rate IP profile on your line is - 444 Kbps
DSL Connection
Link Information
Uptime:1 day, 6:50:15
Modulation:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:444 / 462
Data Transferred (Sent/Received) [MB/MB]:58.04 / 591.92
Output Power (Up/Down) [dBm]:12.5 / 15.5
Line Attenuation (Up/Down) [dB]:19.0 / 37.5
SN Margin (Up/Down) [dB]:23.5 / 31.0
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):10 / 0
FEC Errors (Up/Down):1,295,127 / 107
CRC Errors (Up/Down):2,122 / 0
HEC Errors (Up/Down):242 / 0
Line Profile:Fast
Can someone also link me to the BT BB help line so I can talk to someone about this? All the advice on the website end with "contact your ISP if you need further help" but it doesn't provide any numbers or any links to numbers.
49 REPLIES 49
Message 2 of 50
Re: Last 3 days broadband has been slow.
helpline is 08001114567
Message 3 of 50
before you phone the one thing they will ask is if you have the router connected to the test socket?
have you tried the quiet line test  dial 17070 option 2  should be quiet - best done in master socket with corded phone
Message 4 of 50
Does the quite line test and heard nothing.
Guess that is good. But also bad as the line is ok so now what?
Message 5 of 50
have you connected router to the test socket behind bottom half of master socket?
Message 6 of 50
I think I have, not sure if I did it right tho?
The speed is still slow as ever?
Is the helpline 24/7?
Message 7 of 50
supposed to be but there are post recently suggesting difficulty getting through
Message 8 of 50
Right well, I phone the number. After 30mins of going through options and opitons and options. I finally got through an adviser who was very helpful. Said there was something wrong with my line and should be recifly within 24hours.
Fingers cross it does.
Message 9 of 50
BTW is there a way to see where my nearest exchange is? Or where the exchanges are located around my area?
Message 10 of 50
The easiest way is to use the 'Exchange search' on SamKnows:
http://www.samknows.com/broadband/exchange_search
Put your phone number in there and it will let you know your exchange and other stuff.
Kind regards... Tom
BT Infinity2:
