Message 1 of 34
Latency / Interleaving issue
Hi there,
Around five days ago my ping to various servers has increased by about 20ms. Before hand if I were to ping www.bbc.co.uk id get 20ms average, currently its pinging at 43ms average. My immediate thought was that interleaving had been enabled on my line again for some reason, so I went to the hub stats and it still read Latency Type : Fast. My line stats are pretty much what they have always been, never experienced a drop in connection speed. I've tried everything from wired / wireless connection, connecting my router directly into the master socket, reformatting my computer, pinged from other devices but sadly nothing fixed the issue.
I know this might not seem like a huge problem to some, but I specifically asked for interleaving to be disabled on my line so I could achieve lower ping times, regardless of what downstream speed I get.
One thing to note is that usually when I run a Speedcheck on my line it comes up with an estimated 4mb but since having this issue its reading at 5mb. Could my line possibly have been switched to a different profile? Any help would be deeply appreciated.
33 REPLIES 33
Message 2 of 34
Re: Latency / Interleaving issue
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Message 3 of 34
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 01:08:58
Downstream4,480 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeFast
Noise margin (Down/Up)15.0 dB / 24.0 dB
Line attenuation (Down/Up)46.6 dB / 26.5 dB
Output power (Down/Up)6.8 dBm / 1.6 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)13 / 0
HEC Errors (Down/Up)10 / 0
Error Seconds (Local/Remote)13 / 0
Message 4 of 34
When I attempt to run diagnostics on the wholesale checker I get the following error,
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Message 5 of 34
just keep trying btspeedtester it will work
your connection time is only just 1hr was that a manual reset?
Message 6 of 34
Yep, a manual reset. I've never had issues with the line dropping before.
Message 7 of 34
what about quiet line test
your noise margin is very high at 15db as normal 6db suggesting either line noise or drops/resets in conenction or both
Message 8 of 34
Quiet line test sounds normal, I've had this noise margin since I can remember and as stated ive never had issues with line drops or connection resetting. There has been no physical change on my end since before and after this problem has occured. A tracert to bbc.co.uk to show you what seems to be like interleaving.
Tracing route to www.bbc.net.uk [212.58.244.68]
over a maximum of 30 hops:
  1     3 ms     1 ms     1 ms  api.home [192.168.1.254]
  2    27 ms    27 ms    27 ms  217.47.211.250
  3    26 ms    27 ms    27 ms  217.47.211.161
  4    34 ms    35 ms    35 ms  213.1.69.190
  5    37 ms    35 ms    36 ms  31.55.165.102
  6    35 ms    36 ms    35 ms  31.55.165.33
  7    36 ms    36 ms    35 ms  31.55.165.107
  8    33 ms    34 ms    34 ms  acc1-10GigE-0-2-0.mr.21cn-ipp.bt.net [109.159.25
0.66]
  9    43 ms    43 ms    44 ms  core1-te0-14-0-3.ealing.ukcore.bt.net [109.159.2
50.5]
 10    41 ms    41 ms    42 ms  peer2-xe0-0-0.telehouse.ukcore.bt.net [109.159.2
54.102]
 11    41 ms    42 ms    41 ms  194.74.65.42
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14    44 ms    43 ms    42 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 15    43 ms    45 ms    43 ms  132.185.255.149
 16    42 ms    41 ms    42 ms  bbc-vip113.telhc.bbc.co.uk [212.58.244.68]
Trace complete.
Message 9 of 34
Still getting the same error from the wholesale speedcheck site after 40minutes worth of attempts.
Message 10 of 34
please just keep trying it is the only way to see your IP Profile
