Message 11 of 34
Re: Latency / Interleaving issue
I've tried this test the last few days and also for a good solid hour with no avail. Being able to see my IP profile would be handy, but my connection speed has never been the issue. My issue is that my line says its on fastpath but the pings im getting clearly indicate that im on an interleaved line.
Message 12 of 34
Looking at your noise margin you have been suffering a number of disconnections / restarts of your hub suggesting the connection is unstable you should be connecting at around 5.7 mb
we need to see the IP Profile to help in diagnosing your problem
could you try another traceroute to bbc.co.uk so we can see were any problems may be this should be carried out using a wired connection  at this time i would say  you are on fast path but maybe a congested connection
Are any problems showing at your exchange these links may help you
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
Message 13 of 34
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  api.home [192.168.1.254]
  2    27 ms    27 ms    27 ms  217.47.211.250
  3    80 ms    26 ms    27 ms  217.47.211.161
  4    36 ms    36 ms    35 ms  213.1.69.190
  5    35 ms    36 ms    35 ms  31.55.165.102
  6    35 ms    35 ms    35 ms  31.55.165.33
  7    36 ms    35 ms    34 ms  31.55.165.107
  8    34 ms    36 ms    34 ms  109.159.250.58
  9    45 ms    40 ms    50 ms  core2-te0-13-0-15.ilford.ukcore.bt.net [109.159.
250.36]
 10    41 ms    42 ms    41 ms  peer2-xe0-1-0.telehouse.ukcore.bt.net [109.159.2
54.138]
 11    44 ms    42 ms    42 ms  194.74.65.42
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14    41 ms    43 ms    43 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 15    43 ms    43 ms    44 ms  132.185.255.149
 16    43 ms    42 ms    42 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
I honestly cant remember my noise margin ever being lower to be honest. I never suffer from disconnections, prior to this week ive had months of uptime on my router even with the relatively high noise margin, I've never exactly been happy with my 4mb connection speed particulary in this day and age but its been solid and the ping times have been pretty good. From the tracert shown above though, one could assume that interleaving is infact, active on my line?
Message 14 of 34
Also to add, no reported faults or outtages at my exchange
Message 15 of 34
you now need to maintain a stable connection for the next 3+ days then if needed get the mods help with the interleaving issue and high noise margin
Message 16 of 34
Will leave it running, thanks for the assistance John!
Message 17 of 34
Just a quick update, my line is now giving me a constant 150-180ms to bbc.co.uk. No background programs or devices are using the internet.
Pinging bbc.co.uk [212.58.244.18] with 32 bytes of data:
Reply from 212.58.244.18: bytes=32 time=167ms TTL=50
Reply from 212.58.244.18: bytes=32 time=156ms TTL=50
Reply from 212.58.244.18: bytes=32 time=172ms TTL=50
Reply from 212.58.244.18: bytes=32 time=170ms TTL=50
Ping statistics for 212.58.244.18:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 156ms, Maximum = 172ms, Average = 166ms
Message 18 of 34
just maintain the stable connection for now and keep trying the speedtest please
Message 19 of 34
Quick update, after around 1.5 days worth of connection my latency seems to have reverted to fastpath!
Reply from 212.58.244.18: bytes=32 time=24ms TTL=50
Reply from 212.58.244.18: bytes=32 time=25ms TTL=50
    Minimum = 24ms, Maximum = 25ms, Average = 24ms
Thanks for the help, ill post back if anything changes 🙂
Message 20 of 34
good to hear all ok now it could have been temporary congestion causing the issue
