ZeeGy
Message 1 of 44
Latency (Ping Issues) During on-peak hours almost all days. no gaming for me :/
Sorry all, this is not the 1st thread that I have raised in regards to this, and sadly I feel that it will not be the last either.
I have been using the same line with BT for years, I was once a happy ADSL2+ customer, and since migrating to infinity (an additional luxury paid do enjoy better gaming) it has infact had an adverse effect.
Speeds are fine, all the time. Have no issues at all. The latency however is truly awful. Gaming and even browsing to a degree is unacceptable during peak times.
Examples would include off-peak, playing a game with an average latency of 10-20ms, on peak this can exceed 300ms easily between 7pm and 10pm most evenings, meaning that I cannot enjoy what I am paying for!
I have had numerous engineers being called out to investigate my line, and no fault is ever found… why they cant accept this and investigate the fault further is truly beyond me.
My home setup is as close to perfect as one could have.
My modem, connects to my HH3 with CAT6 Cable, To which my Pc is connected to HH3 via another CAT6 Cable. I have ran tests by plugging another pc into the network to ensure the pc is not at fault… the issue remains the same. All cables have been tested, all internally is fine.
I have been told (numerous times) that there are no issues on my line from my house to the cabinet, everything is fine.
So why is it, that as soon as 7pm comes, I have no chance of gaming at all? What can be done to resolve the issue.
43 REPLIES 43
ZeeGy
Message 2 of 44
Re: Latency (Ping Issues) During on-peak hours almost all days. no gaming for me :/
Have been reading another thread carefully and found this VERY relevant.
http://community.bt.com/t5/BT-Infinity/problem-with-infinity/m-p/406049/highlight/true#M26207
Game : CounterStrike Source / Team Fortress 2 / Other Source Engine based games, yet all seems to be affected Battlefield 3 is no better.
Here is an example of response times off peak, these are acceptable!
Pinging www.bbc.net.uk [212.58.246.93] with 32 byte
Reply from 212.58.246.93: bytes=32 time=17ms TTL=51
Reply from 212.58.246.93: bytes=32 time=18ms TTL=51
Then comes the on-peak tests :
Pinging www.bbc.net.uk [212.58.246.95] with 32 bytes of data
Reply from 212.58.246.95: bytes=32 time=134ms TTL=51
Reply from 212.58.246.95: bytes=32 time=136ms TTL=51
Reply from 212.58.246.95: bytes=32 time=141ms TTL=51
Reply from 212.58.246.95: bytes=32 time=140ms TTL=51
Tracing route to www.bbc.net.uk [212.58.246.95]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms www.asusnetwork.net [192.168.1.254]
2 6 ms 6 ms 6 ms 217.32.141.7
3 7 ms 7 ms 13 ms 217.32.140.222
4 12 ms 12 ms 11 ms 217.41.216.154
5 12 ms 11 ms 11 ms 31.55.164.43
6 12 ms 11 ms 11 ms 31.55.164.107
7 128 ms 129 ms 129 ms acc1-10GigE-0-3-0-3.bm.21cn-ipp.bt.net [109.159.248.114]
8 143 ms 141 ms 137 ms core1-te0-3-0-15.ealing.ukcore.bt.net [109.159.248.28]
9 16 ms 16 ms 16 ms peer1-xe3-2-0.telehouse.ukcore.bt.net [109.159.254.221]
10 19 ms 18 ms 18 ms 194.74.65.42
11 * * * Request timed out.
12 153 ms 157 ms 155 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 152 ms 147 ms 144 ms 132.185.255.165
14 144 ms 145 ms 149 ms bbc-vip016.cwwtf.bbc.co.uk [212.58.246.95]
ZeeGy
Message 3 of 44
Here is todays BQM chart, as you can see this evening will be no different in regards to latency during peak times:
______________________________________________________________________________________________
For anyone that is interested, This is what is documented on the ThinkBroadband Site to help get an overview of what the graphs mean....
http://www.thinkbroadband.com/faq/sections/bqm.html
This graph covers a different time period to the other graphs, but shows what effect a heavily congested link from an exchange to the wider internet can have. In this case the minimum latency climbs from a high but OK 40ms, to over 140ms at the busiest point in the evening. The consistency of the latency, i.e. wide green area with a narrow blue area helps to suggest this is not congestion from a single users line, but the effect of a much larger link becoming saturated. Anyone who is a gamer would not be able to play first person shooters with latency like this at peak times.
Doesnt that look familiar to my initial charts? Funny that isnt it?
ZeeGy
Message 4 of 44
Here are some WinMTR Stats, These help portray latency between each hop while to trying to game on my connection. End server is no-where near capacity with other users (on virgin and other LLU ADSL Products) getting Latencies of less than 30ms at the same time as this test.
WinMTR statistics
Host%SentRecvBestAvrgWrstLast
www.asusnetwork.net04374370020
217.32.141.704374377797
217.32.140.20604374377143427
217.41.216.234043743712121512
31.55.164.189043743712121413
31.55.164.107043743712131513
acc1-10GigE-0-2-0-5.bm.21cn-ipp.bt.net043743799131156138
core2-te0-15-0-17.ilford.ukcore.bt.net0437437116148168129
peer2-xe2-1-0.telehouse.ukcore.bt.net0437437104138235143
194.74.65.42043743716175117
No response from host1008700000
ae0.er01.telhc.bbc.co.uk0437437106136174144
132.185.255.1400437437106136161143
www-vip.telhc.bbc.co.uk043743717172018
ryant704
Guru
Message 5 of 44
Contact the moderators here, they will take personal ownership over your case until resolved.
They normally respond within 3 working days.
The moderators will be able to escalate the problem, keep us Informed please.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
ZeeGy
Message 6 of 44
ryant704, thanks for the prompt response. I had done so with my previous post. and I never had a response. Am happy to do the same again, but i hope that i recieve a better service.
I will not be spamming the board, but I will continue to keep uploading statistics to confirm that this is an ongoing issue. I hope, that it may provide a decent overview when(and IF) someone is willing to assist with my issue.
Sorry to sound so negative, but considering the number of visits i have now recieved i find it doubtfull
ZeeGy
Message 7 of 44
ryant704
Guru
Message 8 of 44
It's a wholesale's fault not Openreachs by looking at it, you can have 100 engineers it won't make any difference.
The mods take 3 working days to respond
ZeeGy
Message 9 of 44
I would have to agree with your comment, sio why am i now on my 10+ fault number with even more engineers coming out? I accept that there are different departments, but you would have assumed by now (and with all this evidence previously supplied) they would have tried to look at other issues in an attempt to resolve the problem.
I have just used the contact the mod section on this post too, so am willing to wait the 3 days for that. however, they have yet to action either of my two last requests. im really, really not trying to be negative here. but i am skeptical regardless.
That said Ryant704, I can only thank you for your prompt responses.
ryant704
Guru
Message 10 of 44
The best way to look at it is like this I think
Openreach - Physical Side
BT Wholesale - Software side
BT Retail - Selling side
That's salted down so you understand what each do
If you don't have a reply within 3 days, check to see if a Moderators is online and message him with the reference you got when sending. They do get lost sometimes happened to me at one point...
