kitch66uk
Message 1 of 2
Latency changed back to Fast and IP Profile stuck at 2Mbps
I seem to have two problems at the moment.  Firstly my latency has been set back to Fast.  This is causing some instability issues (although not as severe as in Dec 2011) and I was getting faster sync speeds and therefore IP profile settings with Interleaved.  My line was supposed to have been turned permanently to Interleaved before Xmas 2011. Thread URL: http://community.bt.com/t5/BB-Speed-Connection-Issues/Slow-speed-since-latency-changed-to-fast/td-p/...
Secondly my IP profile has been set at 2 Mbps for over two weeks.  This is higher than it should be based on the sync speeds I've been getting at the 960kbps level.
Could I be set back to interleaved and my IP profile reset please?
The BT speed tester results and router stats are shown below:
Download speed achieved during the test was - 0.44 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :0.96 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
ADSL Line Status
Connection Information
Line state:           Connected
Connection time:             1 days, 01:25:19
Downstream:    960 Kbps
Upstream:          448 Kbps
ADSL Settings
VPI/VCI:               0/38
Type:     PPPoA
Modulation:       G.992.1 Annex A
Latency type:     Fast
Noise margin (Down/Up):            6.0 dB / 9.0 dB
Line attenuation (Down/Up):     73.8 dB / 31.5 dB
Output power (Down/Up):         15.0 dBm / 12.4 dBm
FEC Events (Down/Up):                0 / 103
CRC Events (Down/Up):                13015 / 560
Loss of Framing (Local/Remote):               0 / 0
Loss of Signal (Local/Remote):   0 / 0
Loss of Power (Local/Remote):  0 / 0
HEC Events (Down/Up):                10200 / 124
Error Seconds (Local/Remote):  5966 / 934
1 REPLY 1
Message 2 of 2
Re: Latency changed back to Fast and IP Profile stuck at 2Mbps
Hi
I am sorry to see you are having promlems with your BT Service
I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
