AslanMods
Message 11 of 29
Re: League of Legends DNS Issues
"C:\Users\*******>nslookip lq.euw1.lol.riotgames.com
Server: BTHomeHub.home
Address: 192.168.1.254
DNS request timed out.
timeout was 2 seconds.
*** Request to BTHomeHub.home timed-out
C:\Users\*******>nsloopup lq.euw1.lol.riotgames.com 8.8.8.8
Server: google-public-dns-a.google.com
Address: 8.8.8.8
Non-authoritative answer:
Addresses: 213.120.234.114
213.120.234.150
C:\Users\*******>nslookip prod.euw1.lol.riotgames.com
C:\Users\*******>nsloopup prod.euw1.lol.riotgames.com 8.8.8.8
Address: 8.8.8.8
213.120.234.150"
NOTE: This is on default BT DNS and with BT Parental Controls enabled.
TheOnlyNemesis
Message 12 of 29
As stated in my post, i was using Google DNS while my girlfriend was using BT DNS of 31.55.187.18 and 31.55.185.26
jac_95
Guru
Guru
Message 13 of 29
@TheOnlyNemesis Thanks. I will highlight this up with SeanD.
@AslanMods Can you please provide the dns name servers your router/Homehub is using?
If you are using the BT Homehub then these can be found within the HomeHubs web GUI by going to http://bthomehub.home/ or http://192.168.1.254 or within your routers web GUI.
For example: 213.120.234.46 & 213.120.234.22
Jackuzi
Message 14 of 29
Same problem here.
Primary DNS: 213.120.234.66
Secondary DNS: 213.120.234.58
AslanMods
Message 15 of 29
I'm not the sole user of my Hub, so currently I'm not at liberty to change the password on it, which apparently I have to do to access hub management.
jac_95
Guru
Guru
Message 16 of 29
Okay no problem AslanMods,
Pop back once you have the owners permission.
BarkWahlberg
Message 17 of 29
Hey SeanD, I work in the NOC at Riot Games. We've emailed your EU NOC with details where players can resolve to our login queue with Google DNS, but not with their default BT DNS, regardless of whether parental controls are enabled or not.
Would you be able to have someone contact us? If you can see my email from my profile feel free to reach out there as well.
scottrc
Message 18 of 29
Oh good, it's not just me then!
Obviously I would rather not have to use the Google DNS, seems a little extreme to give all that data away. Hopefully BT have this fixed soon.
SeanD
Community Manager
Community Manager
Message 19 of 29
Hi BarkWahlberg,
Thanks for the message and welcome to the forum.
I will speak with our network team and be in touch with you as soon as possible.  This will more than likely be tomorrow.  I appreciate you reaching out.
Thanks for all the traceroutes and comments from our customers on this subject.
Cheers
Sean
Sinuous
Message 20 of 29
I was able to fix the problem with parental controls thanks to the help of a distinguished sage named Keith, and was able to use google's DNS servers and indeed I was able to log into League of Legends with no issues whatsoever.
