ESKIBOY
Message 1 of 2
Lease requested
I keep getting disconneted from the Xbox. When i check the router logs i see.
Why is it doing this when i have my Xbox set to always use the same I.P.
17:22:53, 31 Dec.(26194.130000) Lease for IP 192.168.1.64 renewed by host Xbox 360 Lease duration: 30240 min
17:22:53, 31 Dec.(26194.080000) Lease requested
00:08:11, 01 Jan.(50512.280000) Lease for IP 192.168.1.64 renewed by host Xbox 360 Lease duration: 30240 min
00:08:11, 01 Jan.(50512.230000) Lease requested
1 REPLY 1
chris6273
Recognised Expert
Message 2 of 2
Re: Lease requested
By the looks of it, your XBox is disconnecting and reconnecting to the router (Renewing its IP), which can be caused by a faulty connection to the router.
Are you using Wireless or Ethernet to connect your XBox to your router?
If you are using Wireless, try changing the Wireless Channel to a less congested one in the Homehub interface.
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
