As has been posted on here many times already, the upgrade to Plus has reset DLM. Give it 14 days for G.INP to be re-invoked and your speed should be back up.
Any problem after then get back.
Ok so after roperting the issue on here I decided to just call BT and make them aware of the issue I was having so they had it on record. They did try "Tests" which seemed to make my connection worse for a while so advised they would send out an Engineer. I advised that I would rather monitor the connection to see if it improves over the 14 days. I did advise them of G.inp and DLM but they didn't know what I was talking about.
Last night I checked my connection and it had been online for 13 days and so many hours, Tonight I checked it and its now back to 0 days and 18 hours :(. My connection is still lower than minimum. Is there anything else I can do or ask BT to help with?
Strangely tonight I also noticed my mobile wasn't on the wifi and my SSID wasn't showing. I browsed to the router IP to find out that the SSID had changed to Broadcom_02263820 and a completely different WiFi password. Any clue why this has happened?
Jamie
can you repost the router stats please
Product name:
BT Hub 6A
Serial number:
+084316+NQ64155540
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 10 Hours 59 Minutes 59 Seconds
Data rate:
12.18 Mbps / 45.37 Mbps
Maximum data rate:
12175 / 55271
Noise margin:
6.1 dB / 6.5 dB
Line attenuation:
16.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
23191 MB Uploaded / 8291 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
LJCROSS
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
LJCROSS-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:84:C9:B2:1B:0D
Software variant:
Boot loader:
7.33.1
