Recognised Expert
Message 11 of 30
Re: Line Profile lowering for no reason.
It is still dropping, 61.22 now,it should be 77.44 as it has been that for over a year.
In my main post I stated that it was dropping for no reason,but it is obvious to me now that BT are lowering it for some reason only they know about.
My contract runs out in October,and unless my profile goes back to 77.44 before then,I will be returning to VM.
Message 12 of 30
@ironman123 wrote:
Karl,
Crosstalk is caused by bad insulation,or lines crossing each other and each line picking up interference [white noise] from each other,or badly connected lines at the cab etc.
How would you go about finding if that is the cause of the IP speed dropping?
Sage
Message 13 of 30
@Karl_JW wrote:
@ironman123 wrote:
Karl,
By contacting the mods.
Ironman, I suggest you do the same if you haven't already done so.
Before going back to VM, I would check out thier new traffic management recently implemented.
Message 14 of 30
I did a few days ago but I didn't get a confirmation email that I had sent them an email, so I've just done it again.
Message 15 of 30
you do not get a confirmation email from the mods the reference number appears as a new web page after you click on the send button
Recognised Expert
Message 16 of 30
I have already contacted the mods no reply yet,but as they are busy there is no rush.
And as John stated,the reference number [ticket number] is given on the last page that appears when you send the report.
Message 17 of 30
You're right. My bad. I've contacted the mods before, but forgot you don't get a confirmation email.
Message 18 of 30
@MBR123 wrote:
BT should look at achieveing better speeds for the houses that live further away and not concentrating on everyone that lives next to the Fibre cabs for faster throughput. BT please leave the 70/10MB+ peeps alone, they dont need help, concentrate on the lower figures around the country and do something special for them!. 🙂
Im not hijacking this thread, but this is one of the best comments I have seen so far...
Message 19 of 30
That can only happen if BT increase the FTTC capex. Then they could run fibre to more cabinets from fibre enabled exchanges and even roll out FTTC from hundreds more exchanges. TBH I don't feel sorry for those that live in rural or semi-rural areas and then complain about a 2Mbps connection. Move to a city or town if you want fast broadband. Life is full of trade offs.
Recognised Expert
Message 20 of 30
This is what my speeds were up to about 2 weeks ago,so there is no reason for my line profile to be going lower and staying low,or getting even lower by each week that passes.
http://speedtest.net/result/2618404104.png
