AlanF
Message 1 of 22
Line Speed Dropping Again - IP Profile Reduced Once More
I have to admit the Mods on here are very helpful, and since Chris P had my IP Profile reset I have been happily working with speeds in  excess of 3.5+ Mbps, which where I am is not far off the 4 Mbps which I understand is all that my line will allow.
However ...... as my daughter was musing on the fact that things seemed to be taking a little longer once again I just did a speed test, and also checked my Hub stats. Here in brief is what I found:
Download speedachieved during the test was - 1.34 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.75 Mbps
Connection time:    1 days, 06:51:37
So ... I have not apparently had a dropped connection for 30 hours or so, and still my IP Profile has fallen by about 2 Mbps, and the download speed accordingly.
Chris P did say come back if I needed further help, so here I am, although I didn't expect it to be so soon.
Is it possible that Chris or one of the other Mods could find out what may have happened to cause the very quick, and unexpected drop in my speed/IP Profile once again?
Regards,
Alan
21 REPLIES 21
Message 2 of 22
Re: Line Speed Dropping Again - IP Profile Reduced Once More
You now need to maintain a stable connection for the next 3/5 days to see if the IP profile rises automatically if not then the mods can become involved but they must be able to see a 3 days + stable connection first
Message 3 of 22
I suspect you have had one or more hub disconnections which may have caused the noise margin to increase reducing the connection speed and therefore as in my earlier post reduce your IP,profile you need to post your full ADSL stats so. It can be seen what has happened
AlanF
Message 4 of 22
I take your point having been down this road before, but I have not physically disconnected HH4 and as the hub reported a stable connection for 30+ hours at the time I reported the issue again last night I didn't think that was the reason, but, I guess I may be wrong!
I am happy to supply all the stats necessary, but looking in the Events Log, when you say 'full stats' do you literally mean all, as there are several categories listed in the drop-down: All, System, Wan, USB etc... etc...
I make the point because the last date in the category WAN (which I have reported before) is the 5th December, today is of course the 7th. For interests sake here is the latest page (there are obviously more) from the All category:
Recorded events
Time and date    Message
08:11:21, 07 Dec.    (428191.910000) Admin login successful by 192.168.1.65 on HTTP
08:07:00, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.146.211.214 on ppp0)
07:55:46, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 208.76.228.121:80->86.146.211.214:49619 on ppp0)
07:48:21, 07 Dec.    (426811.280000) Device disconnected: Hostname: Debbies-Laptop IP: 192.168.1.66 MAC: c4:17:fe:25:53:1b
07:48:20, 07 Dec.    wlan0: STA c4:17:fe:25:53:1b IEEE 802.11: Client disassociated
07:48:07, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.123.85.43:443->86.146.211.214:49928 on ppp0)
07:47:52, 07 Dec.    BLOCKED 4 more packets (because of Packet invalid in connection)
07:47:51, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.80:443->86.146.211.214:49911 on ppp0)
07:47:50, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.123.85.97:443->86.146.211.214:49897 on ppp0)
07:47:45, 07 Dec.    BLOCKED 5 more packets (because of Packet invalid in connection)
07:47:44, 07 Dec.    BLOCKED 2 more packets (because of Packet invalid in connection)
07:47:43, 07 Dec.    BLOCKED 3 more packets (because of Packet invalid in connection)
07:47:43, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.41.169:443->86.146.211.214:49704 on ppp0)
07:47:17, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:47:17, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.66.95:443->86.146.211.214:49603 on ppp0)
07:46:41, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:46:41, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 77.72.116.168:80->86.146.211.214:49879 on ppp0)
07:46:18, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:46:18, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.26:80->86.146.211.214:49827 on ppp0)
07:45:46, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 91.146.105.191:80->86.146.211.214:49784 on ppp0)
07:45:45, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 91.146.105.191:80->86.146.211.214:49774 on ppp0)
07:45:44, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.75:80->86.146.211.214:49807 on ppp0)
07:44:47, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.66.84:443->86.146.211.214:49731 on ppp0)
07:44:47, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:44:46, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.32:80->86.146.211.214:49723 on ppp0)
07:44:29, 07 Dec.    BLOCKED 6 more packets (because of Packet invalid in connection)
07:44:28, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:44:27, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 192.33.31.101:80->86.146.211.214:49677 on ppp0)
07:44:24, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
07:44:23, 07 Dec.    BLOCKED 2 more packets (because of Packet invalid in connection)
07:44:22, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.41.163:80->86.146.211.214:49624 on ppp0)
07:44:20, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.112:80->86.146.211.214:49605 on ppp0)
07:42:47, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 60.191.252.55:37493->86.146.211.214:80 on ppp0)
07:42:36, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.65:443->86.146.211.214:49545 on ppp0)
07:41:54, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 173.248.166.179:2000->86.146.211.214:80 on ppp0)
07:41:41, 07 Dec.    (426411.610000) Admin login successful by 192.168.1.65 on HTTP
07:41:14, 07 Dec.    (426385.180000) New GUI session from IP 192.168.1.65
07:36:45, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.123.85.97:443->86.146.211.214:49419 on ppp0)
07:36:35, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.123.85.43:443->86.146.211.214:49401 on ppp0)
07:33:52, 07 Dec.    (425942.890000) Lease for IP 192.168.1.66 renewed by host Debbies-Laptop (MAC c4:17:fe:25:53:1b). Lease duration: 1440 min
07:33:52, 07 Dec.    (425942.890000) Device connected: Hostname: Debbies-Laptop IP: 192.168.1.66 MAC: c4:17:fe:25:53:1b Lease time: 1440 min. Link rate: 117.0 Mbps
07:33:52, 07 Dec.    (425942.840000) Lease requested
07:33:52, 07 Dec.    wlan0: STA c4:17:fe:25:53:1b IEEE 802.11: Client associated
07:32:19, 07 Dec.    BLOCKED 3 more packets (because of Packet invalid in connection)
07:32:18, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.41.166:80->86.146.211.214:49363 on ppp0)
07:29:59, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 221.6.51.118:7000->86.146.211.214:8080 on ppp0)
07:26:43, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 188.121.36.239:80->86.146.211.214:49277 on ppp0)
07:23:37, 07 Dec.    (425327.400000) Lease for IP 192.168.1.65 renewed by host AlanF-My-Laptop (MAC 78:dd:08:b8:eb:d8). Lease duration: 1440 min
07:23:37, 07 Dec.    (425327.400000) Device connected: Hostname: AlanF-My-Laptop IP: 192.168.1.65 MAC: 78:dd:08:b8:eb:d8 Lease time: 1440 min. Link rate: 65.0 Mbps
07:23:37, 07 Dec.    (425327.350000) Lease requested
07:23:37, 07 Dec.    wlan0: STA 78:dd:08:b8:eb:d8 IEEE 802.11: Client associated
07:15:31, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.146.211.214 on ppp0)
06:40:50, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19->86.146.211.214 on ppp0)
06:28:13, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 210.16.194.8:4031->86.146.211.214:80 on ppp0)
05:43:20, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19->86.146.211.214 on ppp0)
05:23:52, 07 Dec.    (418143.230000) NTP synchronization success!
05:09:33, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 61.231.6.40:12200->86.146.211.214:80 on ppp0)
04:46:32, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 218.7.37.194:482->86.146.211.214:22 on ppp0)
04:25:49, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.146.211.214 on ppp0)
03:56:50, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 202.109.143.181:7000->86.146.211.214:8080 on ppp0)
03:22:15, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.146.211.214 on ppp0)
03:19:25, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 95.85.31.218:45196->86.146.211.214:80 on ppp0)
02:14:41, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19->86.146.211.214 on ppp0)
02:09:14, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 141.212.121.81:51586->86.146.211.214:443 on ppp0)
02:07:49, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 117.79.91.16:4763->86.146.211.214:22 on ppp0)
01:54:45, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 115.84.101.78:41845->86.146.211.214:80 on ppp0)
01:30:10, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.146.211.214 on ppp0)
01:14:20, 07 Dec.    (403171.210000) Device disconnected: Hostname: Debbies-Laptop IP: 192.168.1.66 MAC: c4:17:fe:25:53:1b
01:14:17, 07 Dec.    wlan0: STA c4:17:fe:25:53:1b IEEE 802.11: Client disassociated
01:10:18, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.64:443->86.146.211.214:51947 on ppp0)
01:07:11, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.73:443->86.146.211.214:51927 on ppp0)
01:07:10, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.190:443->86.146.211.214:51922 on ppp0)
01:06:52, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 92.122.123.89:443->86.146.211.214:51902 on ppp0)
01:06:50, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
01:06:50, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.80:443->86.146.211.214:51888 on ppp0)
00:25:38, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.82:80->86.146.211.214:50388 on ppp0)
00:20:18, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 72.208.58.234:37437->86.146.211.214:80 on ppp0)
00:20:13, 07 Dec.    IN: BLOCK [16] Remote administration (TCP 72.208.58.234:56491->86.146.211.214:8080 on ppp0)
00:18:05, 07 Dec.    (399796.190000) Device disconnected: Hostname: AlanF-My-Laptop IP: 192.168.1.65 MAC: 78:dd:08:b8:eb:d8
00:18:02, 07 Dec.    wlan0: STA 78:dd:08:b8:eb:d8 IEEE 802.11: Client disassociated
00:16:07, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 94.245.121.176:80->86.146.211.214:50150 on ppp0)
00:16:06, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.41.173:80->86.146.211.214:50213 on ppp0)
00:16:05, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.98:80->86.146.211.214:50187 on ppp0)
00:16:02, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.34:80->86.146.211.214:50155 on ppp0)
00:15:58, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.146.191.132:80->86.146.211.214:50047 on ppp0)
00:15:58, 07 Dec.    BLOCKED 10 more packets (because of Packet invalid in connection)
00:15:57, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.146.191.132:80->86.146.211.214:50036 on ppp0)
00:15:57, 07 Dec.    BLOCKED 2 more packets (because of Packet invalid in connection)
00:15:56, 07 Dec.    BLOCKED 9 more packets (because of Packet invalid in connection)
00:15:55, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 213.146.191.132:80->86.146.211.214:50036 on ppp0)
00:15:55, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
00:15:54, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 173.194.67.95:80->86.146.211.214:50035 on ppp0)
00:15:30, 07 Dec.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.146.211.214 on ppp0)
00:15:24, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 87.249.105.58:80->86.146.211.214:50014 on ppp0)
00:15:23, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 87.249.105.58:80->86.146.211.214:50013 on ppp0)
00:15:21, 07 Dec.    BLOCKED 4 more packets (because of Packet invalid in connection)
00:15:20, 07 Dec.    BLOCKED 2 more packets (because of Packet invalid in connection)
00:15:19, 07 Dec.    BLOCKED 1 more packets (because of Packet invalid in connection)
00:15:18, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 68.232.35.139:80->86.146.211.214:50003 on ppp0)
00:15:16, 07 Dec.    IN: BLOCK [9] Packet invalid in connection (TCP 217.32.28.32:80->86.146.211.214:50000 on ppp0)
Regards,
Alan
Message 5 of 22
Hi yes the stats shown in the wan drop down connection speed and noise margin and if you also go to the broadband tab you can locate the connection timed
AlanF
Message 6 of 22
Here are the latest stats in the WAN category. The latest date is 5th december, so if anything happened between then and today, the 7th, it's not yet visible in the WAN logs:
16:56:31, 05 Dec.    (286903.540000) WAN operating mode is DSL
16:56:31, 05 Dec.    (286903.540000) Last WAN operating mode was DSL
16:56:31, 05 Dec.    (286903.510000) PPPoA is up - VPI: 0, VCI:38
16:56:31, 05 Dec.    (286902.990000) PPP IPCP Receive Configuration ACK
16:56:31, 05 Dec.    (286902.960000) PPP IPCP Send Configuration Request
16:56:31, 05 Dec.    (286902.960000) PPP IPCP Receive Configuration NAK
16:56:31, 05 Dec.    (286902.940000) PPP IPCP Send Configuration ACK
16:56:31, 05 Dec.    (286902.940000) PPP IPCP Receive Configuration Request
16:56:31, 05 Dec.    (286902.940000) PPP IPCP Send Configuration Request
16:56:31, 05 Dec.    (286902.940000) CHAP authentication successful
16:56:30, 05 Dec.    (286902.500000) CHAP Receive Challenge
16:56:30, 05 Dec.    (286902.500000) Starting CHAP authentication with peer
16:56:30, 05 Dec.    (286902.500000) PPP LCP Receive Configuration ACK
16:56:30, 05 Dec.    (286902.470000) PPP LCP Send Configuration Request
16:56:30, 05 Dec.    (286902.470000) PPP LCP Receive Configuration Reject
16:56:30, 05 Dec.    (286902.470000) PPP LCP Send Configuration ACK
16:56:30, 05 Dec.    (286902.470000) PPP LCP Receive Configuration Request
16:56:30, 05 Dec.    (286902.190000) PPP LCP Send Configuration Request
16:56:28, 05 Dec.    (286900.170000) ETHoA is up - VPI: 0, VCI:35
16:56:28, 05 Dec.    (286900.170000) DSL is up
16:56:27, 05 Dec.    (286899.250000) DSL noise margin: 22.00 dB upstream, 6.00 dB downstream
16:56:27, 05 Dec.    (286899.180000) DSL line rate: 448 Kbps upstream, 1984 Kbps downstream
16:55:56, 05 Dec.    (286868.660000) DSL is down after 1875 minutes uptime
16:55:56, 05 Dec.    (286868.660000) ETHoA is down after 1875 minutes uptime
16:55:56, 05 Dec.    (286868.360000) PPPoA is down after 1875 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)]
16:55:52, 05 Dec.    (286864.860000) PPP LCP Send Termination Request [User request]
09:40:26, 04 Dec.    (174338.330000) WAN operating mode is DSL
09:40:26, 04 Dec.    (174338.330000) Last WAN operating mode was DSL
09:40:26, 04 Dec.    (174338.290000) PPPoA is up - VPI: 0, VCI:38
09:40:25, 04 Dec.    (174337.780000) PPP IPCP Receive Configuration ACK
09:40:25, 04 Dec.    (174337.750000) PPP IPCP Send Configuration Request
09:40:25, 04 Dec.    (174337.750000) PPP IPCP Receive Configuration NAK
09:40:25, 04 Dec.    (174337.730000) PPP IPCP Send Configuration ACK
09:40:25, 04 Dec.    (174337.730000) PPP IPCP Receive Configuration Request
09:40:25, 04 Dec.    (174337.730000) PPP IPCP Send Configuration Request
09:40:25, 04 Dec.    (174337.720000) CHAP authentication successful
09:40:25, 04 Dec.    (174337.270000) CHAP Receive Challenge
09:40:25, 04 Dec.    (174337.270000) Starting CHAP authentication with peer
09:40:25, 04 Dec.    (174337.270000) PPP LCP Receive Configuration ACK
09:40:25, 04 Dec.    (174337.240000) PPP LCP Send Configuration Request
09:40:25, 04 Dec.    (174337.240000) PPP LCP Receive Configuration Reject
09:40:25, 04 Dec.    (174337.240000) PPP LCP Send Configuration ACK
09:40:25, 04 Dec.    (174337.240000) PPP LCP Receive Configuration Request
09:40:24, 04 Dec.    (174336.940000) PPP LCP Send Configuration Request
09:40:22, 04 Dec.    (174334.930000) ETHoA is up - VPI: 0, VCI:35
09:40:22, 04 Dec.    (174334.930000) DSL is up
09:40:21, 04 Dec.    (174334.000000) DSL noise margin: 23.00 dB upstream, 6.00 dB downstream
09:40:21, 04 Dec.    (174333.930000) DSL line rate: 448 Kbps upstream, 4192 Kbps downstream
09:39:51, 04 Dec.    (174303.820000) DSL is down after 1135 minutes uptime
09:39:51, 04 Dec.    (174303.820000) ETHoA is down after 1135 minutes uptime
09:39:51, 04 Dec.    (174303.530000) PPPoA is down after 1135 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)]
09:39:47, 04 Dec.    (174300.020000) PPP LCP Send Termination Request [User request]
14:44:16, 03 Dec.    (106169.200000) WAN operating mode is DSL
14:44:16, 03 Dec.    (106169.200000) Last WAN operating mode was DSL
14:44:16, 03 Dec.    (106169.160000) PPPoA is up - VPI: 0, VCI:38
14:44:15, 03 Dec.    (106168.650000) PPP IPCP Receive Configuration ACK
14:44:15, 03 Dec.    (106168.630000) PPP IPCP Send Configuration Request
14:44:15, 03 Dec.    (106168.630000) PPP IPCP Receive Configuration NAK
14:44:15, 03 Dec.    (106168.600000) PPP IPCP Send Configuration ACK
14:44:15, 03 Dec.    (106168.600000) PPP IPCP Receive Configuration Request
14:44:15, 03 Dec.    (106168.600000) PPP IPCP Send Configuration Request
14:44:15, 03 Dec.    (106168.600000) CHAP authentication successful
14:44:15, 03 Dec.    (106168.260000) CHAP Receive Challenge
14:44:15, 03 Dec.    (106168.260000) Starting CHAP authentication with peer
14:44:15, 03 Dec.    (106168.260000) PPP LCP Receive Configuration ACK
14:44:15, 03 Dec.    (106168.240000) PPP LCP Send Configuration Request
14:44:15, 03 Dec.    (106168.240000) PPP LCP Receive Configuration Reject
14:44:15, 03 Dec.    (106168.240000) PPP LCP Send Configuration ACK
14:44:15, 03 Dec.    (106168.240000) PPP LCP Receive Configuration Request
14:44:15, 03 Dec.    (106167.830000) PPP LCP Send Configuration Request
14:44:12, 03 Dec.    (106164.830000) PPP LCP Send Configuration Request
14:44:10, 03 Dec.    (106162.820000) ETHoA is up - VPI: 0, VCI:35
14:44:10, 03 Dec.    (106162.820000) DSL is up
14:44:09, 03 Dec.    (106161.910000) DSL noise margin: 22.00 dB upstream, 6.20 dB downstream
14:44:09, 03 Dec.    (106161.840000) DSL line rate: 448 Kbps upstream, 1888 Kbps downstream
14:43:38, 03 Dec.    (106131.630000) DSL is down after 1376 minutes uptime
14:43:38, 03 Dec.    (106131.630000) ETHoA is down after 1376 minutes uptime
14:43:38, 03 Dec.    (106131.350000) PPPoA is down after 1375 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)]
14:43:35, 03 Dec.    (106127.900000) PPP LCP Send Termination Request [User request]
15:47:42, 02 Dec.    (23576.090000) WAN operating mode is DSL
15:47:42, 02 Dec.    (23576.090000) Last WAN operating mode was DSL
15:47:42, 02 Dec.    (23576.060000) PPPoA is up - VPI: 0, VCI:38
15:47:42, 02 Dec.    (23575.540000) PPP IPCP Receive Configuration ACK
15:47:42, 02 Dec.    (23575.510000) PPP IPCP Send Configuration Request
15:47:42, 02 Dec.    (23575.510000) PPP IPCP Receive Configuration NAK
15:47:42, 02 Dec.    (23575.490000) PPP IPCP Send Configuration ACK
15:47:42, 02 Dec.    (23575.490000) PPP IPCP Receive Configuration Request
15:47:42, 02 Dec.    (23575.490000) PPP IPCP Send Configuration Request
15:47:42, 02 Dec.    (23575.490000) CHAP authentication successful
15:47:42, 02 Dec.    (23575.390000) CHAP Receive Challenge
15:47:42, 02 Dec.    (23575.390000) Starting CHAP authentication with peer
15:47:42, 02 Dec.    (23575.390000) PPP LCP Receive Configuration ACK
15:47:42, 02 Dec.    (23575.360000) PPP LCP Send Configuration Request
15:47:42, 02 Dec.    (23575.360000) PPP LCP Receive Configuration Reject
15:47:42, 02 Dec.    (23575.360000) PPP LCP Send Configuration ACK
15:47:42, 02 Dec.    (23575.360000) PPP LCP Receive Configuration Request
15:47:41, 02 Dec.    (23575.070000) PPP LCP Send Configuration Request
15:47:38, 02 Dec.    (23572.070000) PPP LCP Send Configuration Request
15:47:35, 02 Dec.    (23569.070000) PPP LCP Send Configuration Request
15:47:33, 02 Dec.    (23567.060000) ETHoA is up - VPI: 0, VCI:35
Regards,
Alan
Message 7 of 22
try just one restart it may resolve the problem
AlanF
Message 8 of 22
I did a reset as you suggested and the speed & IP Profile do seem to be on the way back. Having just done a speedtest, here are the results:
 Download speed achieved during the test was - 3.14 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 3.22 Mbps
I guess that if there are no further unexpected connection losses that the speed/IP Profile should still show a further, albeit, marginal improvement, to get back to what it was the other day.
Thanks for your help.
Regards,
Alan
Message 9 of 22
Without being able to see your current connection speed it is hard to say how much if any more your IP Profile may increase i suspect they are already fairly close to its correct level
Moderator-Retired
Message 10 of 22
Hi AlanF
Looks like John has this well in hand but just thought I would mention that if you need to get back to the mods just reply to the last email ChrisP sent and we can have another look if needs be.
Of course posting here would be first point of call as your IP profile is on the way up again however the mods are always happy to help out when needs be.
ta
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
