Pancho78
Message 1 of 15
Line bonding??
Was thinking today when waiting for the btor man show up about line bonding as my previouse suppliyer BE had offered it to me before I left them for bt .I know you need a second phone line and a special router to give you twice your original line speed but was wondering would it also work with infinity ? Don't get me wrong my speed is fantastic now but wanted to know if anyone new if this would work with fttc or not??
14 REPLIES 14
Message 2 of 15
Re: Line bonding??
Yep it's been tests. Not sure by who, I don't think Openreach but it gave speeds of about 450meg at 300m over standard copper I believe.
That's using the 30a profile on VDSL2.
deathaxe
Expert
Message 3 of 15
Re: Line bonding??
The report I saw was some company in israel trialing it.
Given that you would need the 2 lines, and a line bonded router etc, perhaps the FTTP on demand that openreach are promising next year is a more likely scenario. and possibly cheaper.
jussa21
Message 4 of 15
Re: Line bonding??
how do i find what profile i am on 17a or other
Message 5 of 15
Re: Line bonding??
Everyone is on the 17a profile.
jussa21
Message 6 of 15
Re: Line bonding??
webby what is 30a profile
Message 7 of 15
Re: Line bonding??
The utilisation of 30MHz of the spectrum as opposed to 17.664MHz at the moment on the 17a profile.
Basically allows more frequencies for higher speeds.
jussa21
Message 8 of 15
Re: Line bonding??
thanks webby will 30a work on fttc or is it for fttp
Message 9 of 15
Re: Line bonding??
FTTC.
Guru
Message 10 of 15
Re: Line bonding??
I know it's not for FTTC, but Be* do line bonding, will be interesting what will happened once they incorporate fibre optics.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
