Message 11 of 15
Re: Line dropping and high Noise margin follwing Exchange upgrade
Yes once your line is stable again yorcspeed will start to improve but the most important thing is a constant connection and no restaarts
Message 12 of 15
will it ever go back up yo the initial 10.8 Mbps or was that unstable for my line, thus the drops?
This is the last question i will bother you lot with, if the speed has dropped due to the restarts and phone issue, this isnt permanent is it? The line will eventually settle at what is best/most stable?
Thanks again all !!
Message 13 of 15
hi you already have a 10.8 mb connection at the moment as your hub stats show
As Keith has posted your noise margin has room to reset and that could also cause an increase in your connection speed
Message 14 of 15
my line was upgraded about a month ago - speed a bit better   However recently my connection fails after I receive a phone call so not sure what to do ?   Mike
Message 15 of 15
HI mikepd63
Could you start you own new post please to save confusion as your problems are different and it will save getting confused replies
