Hi, I've had my line repaired today after being without service since the 17th January.
I have checked my connection speed on the HH5 and can see it is synced at a slower speed than it should be.
I have googled the best line attenuation and noise margin, but get different answers. Some say higher the better, others say lower.
Should I be expecting more from my connection with these results.....?
Any help would be great.
Why's your hub only been up for 1 1/2 hrs?
Are you on infinity or adsl/copper
FTTC if that helps any, although the package i'm on is 'faster broadband' because of distance
Bit of a misnomer that @imjolly as VDSL is also copper.
Op have you tried connecting to the test socket with a filter? Is there any noise on your line 17070 option 2, any noise report a line fault con't mention broadband.
@pippincp Must have been clear enough as I got the answer
Can you enter phone number and post results. Remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
Did you see post 3 @imjolly?
