Message 11 of 22
Re: Line speed and attenuation
@pippincp Yes thanks
i was just wanting to see what connection speed estimated compared to the line which has had severe problems and now just been fixed. Assuming was broadband engineer pity he did not reset the DLM before leaving
Message 12 of 22
Would you guys say that the original post picture was in an acceptable range for noise?
Message 13 of 22
No I was comparing attainable with the estimate. If your noise margin gets back to normal 6db then speed should move nearer your attainable speed. If the fix was by a broadband engineer I am surprised that did not reset DLM. If phone engineer then he could not arrange DLM reset
Message 14 of 22
What you posted means nothing without context. That's why you are being requested for further info.
Message 15 of 22
Just had another drop connection, I've done the line test and I can hear a hi pitch noise, not in your face loud, but its there.
Message 16 of 22
Then get engineer back
before that have you tried using the test socket with a filter to see is still line noise
Message 17 of 22
I ran the test via the test socket, that would explain the drop out in connection. The noise was present. Faint, but there. The engineer that came last week (broadband engineer) said that the line from the pole to the master was too close to the incoming power line to the house. He was going to request that was moved away as this could be the issue with interference, needless to say the engineer today (I didnt see him as I was in work) has not moved the line.
Message 18 of 22
I shouldn't complain really, at least I have a connection I can use and is faster than 500Kbps down and up......
Message 19 of 22
Your electricity supply is via overhead? Not mocking as there are many places that are the same.
Message 20 of 22
Yeah. I live in rural Cheshire. Overhead phone, electricity. No mains drainage, no gas supply and very iffy mobile phone signal. But hey, I get to wake up each morning and look out onto fields.
Who am I kidding, I need to move!
