Message 11 of 20
Re: Line speed at 4.3 MBPS speed test at 100 KBPS
FAQ Results Image not loaded 1. Best Effort Test: -provides background information. Download Speed 0.11 Mbps 0 Mbps 0.25 Mbps Max Achievable Speed Download speedachieved during the test was - 0.11 Mbps For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps. Additional Information: Your DSL Connection Rate :6.75 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 0.14 Mbps If you wish to discuss these results please contact your Broadband Service Provider. If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance. Your test has completed please close this window to exit the performance tester.
Message 12 of 20
well i misclicked and said it was solved any way to change this
Message 13 of 20
Your problem is low profile due to a previouly low connection speed. Just stay connected 24/7 for 3/5 days and it should automatically increase to correct level for connection speed
Message 14 of 20
That would be reassuring if it hadn't already like this for 5 days
Message 15 of 20
It is 3/5 days stable connection with no resets and it will automatically increase
Your current connection time is only 1+ hrs
Your correct profile should be 5.5mb based on current connection speed
Message 16 of 20
So there's absolutely nothing I can do for another week
Tags (1)
Message 17 of 20
You have a very low IP profile you now need to maintain a stable connection with NO HUB RESTARTS for the next 3/5 days and your profile will rise automatically and your download speed will I then improve at the same time
Message 18 of 20
Correct just ensure no restarts at all it is the only cure just keep a regular check on the hubs connection time
Message 19 of 20
*sigh* well thanks
Tags (1)
Message 20 of 20
your previous line problems have been the cause of the disconnections which has dropped the IP Profile a stable connection s the only cure
