john46
Message 11 of 22
Re: Line speed incredibly slow
your profile could be banded and will release automatically after it releases if the noise margin is still high then it will need the mods assistance but 3days + must be shown on your hub connection time first connecting a phone via a filter is no problem
imjolly
Message 12 of 22
John46 I don't think it is in a banded profile ( connection speed normally 288 and noise margin at least 15db) but probably as astar27 said an external problem especially if already connected to test socket
john46
Message 13 of 22
yes i think you are correct it looks like it needs mod assistance something is certainly strange about the connection
djeffer
Message 14 of 22
Morning all,
Have connected direct to the test socket and will leave it for at least 3 days as requested.
This mornings results as follows.
ADSL Line Status
Connection Information 14th June 2012, 10:45
Line state:
Connected
Connection time:
0 days, 01:22:44
Downstream:
284.4 Kbps
Upstream:
732 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
Noise margin (Down/Up):
9.7 dB / 6.1 dB
Line attenuation (Down/Up):
62.9 dB / 40.7 dB
Output power (Down/Up):
14.9 dBm / 12.5 dBm
FEC Events (Down/Up):
537290 / 4846
CRC Events (Down/Up):
2003 / 940
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
HEC Events (Down/Up):
3775 / 1613
Error Seconds (Local/Remote):
35351 / 5914
Speak to you again in a few day.
Thanks for your help so far.
Cheers
Dave
john46
Message 15 of 22
if no improvement in 3 days we can put you in touch with the forum moderators to investigate your connection further
djeffer
Message 16 of 22
Morning all,
I know it is neccessary to have 3 days run on the connection, but.
Here is the data at 01:00 this morning
ADSL Line Status
Connection Information   16th June 2012, 01:02
Line state:
Connected
Connection time:
1 days, 14:29:19
Downstream:
284.4 Kbps
Upstream:
732 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
6.2 dB / 6.3 dB
62.9 dB / 40.7 dB
14.9 dBm / 12.5 dBm
8942756 / 49258
37022 / 9083
0 / 0
0 / 0
0 / 0
51690 / 24669
38614 / 7757
 And here is the data at 10:45 this morning.
ADSL Line Status
Connection Information   16th June 2012, 10:45
Line state:
Connected
Connection time:
0 days, 05:48:36
Downstream:
284.4 Kbps
Upstream:
732 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
3.7 dB / 6.0 dB
62.9 dB / 40.7 dB
14.9 dBm / 12.5 dBm
18646325 / 58910
63776 / 9979
0 / 0
0 / 0
0 / 0
92613 / 26437
41321 / 8027
 It looks like there was disconnection about 5 am.
I have noticed that over the last week or so this appears to happen regularly.
Note that we haven't had any power cuts at all.
Any suggestions?
Dave
imjolly
Message 17 of 22
you need mod help
contact mods
can take up to 3 working days for mods to contact you
john46
Message 18 of 22
the connection certainly has problems and needs the mods intervention use the link imjolly has posted
djeffer
Message 19 of 22
Afternoon all,
Result.
Well the BT Broadband Engineer has been, arrived 08:30, and left around 10:00.
Fitted another new socket and removed an 'old' (35years) repeater bell that the previous engineer stated he had disconnected. He obviously hadn't.
The engineer today also changed over lines at the local cabinet and also at the exchange.
From 288kbs
Connection Information  21st June 2012, 08:30
Line state:
Connected
Connection time:
2 days, 05:27:14
Downstream:
284.4 Kbps
Upstream:
691.1 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
10.0 dB / 6.1 dB
63.4 dB / 40.8 dB
14.9 dBm / 12.6 dBm
9424606 / 52832
36391 / 7172
0 / 0
0 / 0
0 / 0
55493 / 11656
57875 / 12567
it has jumped to over 3 Mbs.
Connection Information  28th June 2012, 11:30
Line state:
Connected
Connection time:
0 days, 00:41:14
Downstream:
3.523 Mbps
Upstream:
967.9 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
Unknown or no mode configured
Latency type:
Fast
6.1 dB / 5.7 dB
54.7 dB / 34.0 dB
18.1 dBm / 12.6 dBm
0 / 0
1693 / 23
0 / 0
0 / 0
0 / 0
2668 / 29
814 / 17
Excellent result.
Thanks everyone for all your help.
Will let it settle down now for some days.
Cheers
David
imjolly
Message 20 of 22
what an improvement  your attenuation has dropped from 63.4 to 54.7 suggesting a serious resistence problem has now been fixed giving you better speed.  connection speed ia about right for your new attenuation
as you say let is settle and then post new stats
great result by engineer
