pavr27
Newbie
Message 1 of 6
LineSaver - what do I get?
Hi, Looking to return to BT if the LineSaver option gives me what I need.
The info on the BT site is non existent or hard to find - I know how much LineSaver costs, but what I do not know is what I get for my money.
1) Are any calls included?
2) What free calling features are included (for example caller display)
5 REPLIES 5
syops
Recognised Expert
Message 2 of 6
Re: LineSaver - what do I get?
If you mean Line Rental Saver, have a look here:
http://bt.custhelp.com/app/answers/detail/a_id/13962/kw/line%20saver/c/345,350,5518
also BT Basic may interest you:
http://www.bt.com/includingyou/other-products-services-bt-basic.html?s_cid=con_FURL_btbasic
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. 🙂 ***
Patty-L
Recognised Expert
Message 3 of 6
Hi There, you would also have to sign up to one of the Phone or
Phone & Broadband packages to get any calls or calling features
as they are not included in the line rental saver.
pavr27
Newbie
Message 4 of 6
Wow, didn't expect replies so quickly!
Ah OK - I understand, for minimum cost (I rarely make calls from my landline, all I need is a line for broadband, not with BT though) I would select the weekend calls package at £0 and then opt for Line Rental Saver - and the calling features included are those specified for the Weekend package.
Thanks!
justatwork
Message 5 of 6
With Line rental saver you get free weekends calls, you get 1471, caller display and 1571 free as long as you make 2 calls through bt a month. You also need to be making 2 calls a month through BT if you take line rental saver to avoid any other charges.
Distinguished Guru
Message 6 of 6
But they can be some of the free calls that you are entitled too, so make your 2 calls in your free period.
toekneem
(EASBF)
