Message 1 of 5
Link Halo 2 and Halo 1 (Slave Router)
How do I link Halo 2 and Halo 1 (Slave Router) so that I can run ethernet cable to TV.    It appears that it was possible with the previous Hubs.
4 REPLIES 4
Message 2 of 5
Re: Link Halo 2 and Halo 1 (Slave Router)
@JP76
They cannot be linked via wireless, so you would still have to run an Ethernet cable to the TV.
Message 3 of 5
Thank you.  I did wonder. There is nothing on on youtube, only relating to Hub wifi linking
Message 4 of 5
Do you have BT TV, or is it just a smart TV you are trying to connect?
If its just a smart TV, then this should do fine..
https://shop.bt.com/products/bt-broadband-extender-600-kit-084284-BVFL.html
It will link the TV to the home hub using the mains wiring.
Message 5 of 5
Thanks. Yes, I had considered as alternative.
