KopGoofer
Message 1 of 7
Linksys EA6900 configuration for BT
Hi All
I have been having a few issues with my BT homehub, disconnecting, dropping connection, etc. so I decided to try a different router to see if it was actually the BT homehub causing the problem. However I cannot find anywhere where there are a list of settings to use - does anyone know what they are?
Basically, I have tried:
Connection Type: PPPoE (only other options I have are PPTP, L2TP, Bridge Mode and Static)
Username: bthomehub@btbroadband.com
Password: BT
Service Name (Optional): BT
Oh and I had seen on post that mentions changing the MTU to 1492.
Can anyone help?
Thanks in advance.
KopGoofer
6 REPLIES 6
Rottie
Recognised Expert
Message 2 of 7
Re: Linksys EA6900 configuration for BT
@KopGoofer wrote:
Hi All
Password: BT
Can anyone help?
Thanks in advance.
KopGoofer
Try leaving the password field blank.
licquorice
Message 3 of 7
Have you got a separate modem? The EA6900 is just a router not a modem/router, i.e you can't connect it directly.
KopGoofer
Message 4 of 7
Hi Rottie
Thanks for you answer, unfortunately you cannot leave it blank - i added in BT as the password word because it was mentioned in this post below:
http://bt.custhelp.com/app/answers/detail/a_id/644/~/how-do-i-configure-my-non-bt-router-to-work-wit...
Kopgoofer
KopGoofer
Message 5 of 7
Hi Licquorice
Sorry should have mentioned, I just regular broadband and the router is a broadband Smart-Wifi Router.
http://www.linksys.com/en-apac/products/routers/EA6900
Kopgoofer
licquorice
Message 6 of 7
Precisely, its just a router. It won't work on its own without a modem.
KopGoofer
Message 7 of 7
I am an idiot!
Thanks for your help! 🙂
Kopgoofer
