jazzguy
Message 31 of 314
Re: List of Routers to replace Home Hub 3.
I replaced my HH3 with the Billion Bipac 7700n - the scaled down version of the 7800n.
I've had 3 HH3s and all had a tendancy to re-boot in response to external line problems - with a resultant increase in snr and drop in download speed. The 7700n is much more robust in this respect - it resyncs every now and then, but snr and download speeds are maintained.
All of which is  a pity as the HH3 is an attractive router and has useful features such as power save.  Bt need to either provide a reliable high performance router or not bother to provide one at all.
Doct0r
Message 32 of 314
Compatible Routers
Hi. About to upgrade to broadband option 2 as 10gb is no longer enough. Have survived this long without a home hub but know that when the upgrade to infinity is available, I might need it then. Currently using a TP-Link 8840T, I know this won't be compatible with infinity but will the TL-R460 work? I don't need wireless or anything complicated. I don't know if it's worth the £29 fee for a HH3 when I can get the TL-R460 for less than half that but will the engineer refuse to connect to anything but a Home Hub. Many thanks in advance.
jonstatt
Message 33 of 314
Re: Compatible Routers
I have a feeling BT insist on you having a HH3 when installing Infinity even if you throw it away after. I am not sure.
Anyway, the top of the range Netgear WNDR4500 should work fine for those that want the dual-band 450MBps Wi-Fi. I am currently using this with a Netgear DG834 via PPPoE on an ADSL2+ connection. It does not support PPPoA so this will only work with very specific ADSL modems, but fine with any Infinity modem.
jamjar62
Expert
Message 34 of 314
jpadeutsch
Message 35 of 314
In reply to Doctor. What £29 fee for HH3? It should be free with Infinity. Billing did make a mistake and put £49 ion my bill for the hub, but cancelled it as soon as I called them.
jonstatt
Message 36 of 314
The HH3 is free but you pay for delivery....6 pound something if I recall.
TimNorton
Message 37 of 314
Hi Guys
we can add another one to the list Smiley Happy
Netgear WNDR3300 - old i know but still better than the HH3 B i have been putting up with for the last couple of months
just reset to fatory default, ran the setup wizard poped in bthomehub@btbroadband.com as user name and away you go!
just run a couple of tests
have been suffering from slow downs during evening/night for last couple of weeks - hope this may solve the problem - figers crossed Smiley Happy
jpadeutsch
Message 38 of 314
Yes, but £6 as you say, not £29.
Doct0r
Message 39 of 314
Infinity isn't available for me right now. I want to upgrade from normal up to 20mb option 1 to option 2. I've never had a home hub but was led to understand that when infinity is available in my area it's a free upgrade (plus the activation fee). If necessary I'd rather have the home hub now than later when they could charge more.
jpadeutsch
Message 40 of 314
Ah, I understand now. But why do you want to get an HH3 now? What you've got should work equally well on option 2 as on option 1. An engineer won't need to visit you for a change in your non-infinity package. When you go to infinity they should supply the HH3 free (apart from the £6 delivery charge). I don't think they are likely to start charging for the hub.
Have they actually told you that it would cost you £29 to get an HH3? If they have never supplied you with a hub, I'd have expected it to be free to you. But then who knows how BT's minds work?
