meridius
Message 61 of 314
Re: List of Routers to replace Home Hub 3.
Anyone help on the post I made above ?
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
Keith_Beddoe
Message 62 of 314
meridius
Message 63 of 314
meridius
Message 64 of 314
Nope I asked a different question in my post in here
Alan63
Expert
Message 65 of 314
Meridius,
1. I would wait the 10 days. Others have changed straight way. So upto you.
2. Hh3 is good but simple router. I had zero issue with it . Good wifi coverage and simple to setup. Only recently changed to apple product but would have no issues reusing if I needed it.
3. No idea. Someone else might know
meridius
Message 66 of 314
cheers for the help
Eipilice
Message 67 of 314
Hello, thinking of buying Netgear WNDR3700 to replace my home hub 3,
Reason for this is home hub only has 1 1gb port, and I have to reset router a lot due to speed dropping.
I use ps3 a lot for online gaming, wired connection, I use pc, laptop also wired. Then ps vita, Xbox , 3x iPhone and iPad wireless.
What I would like to know is... Is the Netgear WNDR3700 a good choice? And can someone give me a setup guide? Do I need infinity username /password etc. is port forwarding and dmz straight forward?
Thanks in advance 🙂
smartie
Message 68 of 314
I'm going to swap the hh3 for a NetGear wndr4500 after the first 10 days are up, been using NetGear routers for years and the 4500 is highly recommended.
Eipilice
Message 69 of 314
What's the difference between wndr4500 and wndr3700?
Cheers
Aarong
Guru
Message 70 of 314
Increased wireless range and speeds etc. Heres both if you want to take a look, http://www.netgear.com/home/products/wirelessrouters/ultimate-performance/wndr4500.aspx#two
http://www.netgear.co.uk/home/products/wirelessrouters/high-performance/WNDR3700.aspx#two
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
