MikeLanglois
Message 1 of 4
Living In A Block Of Flats Slowing My Speed?
Hi all,
I recently lived in a Infinity property with no problems at all. I have just moved in to a new flat in a block of flats and the speed is at best 2mbps. While this is slow, it feels even slower than that sometimes.
I was wondering, would the fact I am in a block of flats effect my speed? Would we all be running off of one line in/out of the building? If so, is it possible to have a dedicated line fitted?
Hopefully not silly questions, thanks.
3 REPLIES 3
john46
Message 2 of 4
Re: Living In A Block Of Flats Slowing My Speed?
every customer has their own individual line living in a block of flats will not affect your speed
have you tried connecting to the test socket to eliminate any internal extension wiring
john46
Message 3 of 4
can you please run the BT speedtest further diagnostic test this test appears after the first test completes and post back the results
http://speedtest.btwholesale.com/
imjolly
Message 4 of 4
can you try quiet line test  dial 17070 option 2  should be quiet and best with corded phone   if cordless then dull hum normal
can you post the adsl stats from your router?
