NeilO
Moderator
Moderator
Message 201 of 491
Re: Locked out of bt email - stuck in a loop
@kinetic747 That's great, I'm glad it's sorted.
cautiousrob
Message 202 of 491
Hi NeilO
Just to update you and the other Mods, I had to do (yet another) password reset yesterday noon, since when everything has been behaving itself.
24 hours and no more problems, maybe it's fixed . . .
Fingers crossed!
Thanks for your help
Rob.
Damian99
Message 203 of 491
"touch wood" i also have been able to keep access without the need to reset the password every other hour, for the last 24 hours. So hopefully it's sorted now.
Thanks (to whoever may have sorted it)
daisymay
Message 204 of 491
Mine's still not working. (Perhaps they're being fixed one at a time...) Still get 'incorrect password' message, regardless of resets, and trying to get in via a roundabout way. Please fix, someone!
kinetic747
Message 205 of 491
Gone again after the security breach text, what the hell is going on?
DanielS
Moderator
Moderator
Message 206 of 491
Hi @kinetic747,
Have you tried logging in through BT.com/mail? It should take you through the online recovery process. Let me know if it does. Don't reset the password before trying this please.
Thank you
DanielS
kinetic747
Message 207 of 491
Tried logging in and it's asking for security question and password reset, shall I go ahead?
DanielS
Moderator
Moderator
Message 208 of 491
Yes please @kinetic747.
Let me know if it gets your access back as it should.
DanielS
kinetic747
Message 209 of 491
Yes I've got access back but why is it happening?
daisymay
Message 210 of 491
I tried logging in like this, but it first refused my password, then said my security info was wrong! (My date of birth etc.?? Most definitely correct!) I'm fed up....
