G3PQB
Message 1 of 5
Log in to BT Yahoo
Hi,
 Can anyone advise me how to display the tick box on the BT Yahoo home page. At the moment I have to log on every time I want to access the internet. As the box is not displayed. I am using XP and the Firefox browser.On my Brothers PC using the same, XP and Firefox the tick box is displayed all OK.
Many thanks,
Sid.
4 REPLIES 4
IanC
Recognised Expert
Message 2 of 5
Re: Log in to BT Yahoo
@G3PQB wrote:
Hi,
You can use the rest of The Internet without logging in there.  You only need to login if you wish to use the BTYahoo portal.
Are you using any ad-blocking etc software or browser add-ons ?
G3PQB
Message 3 of 5
Thank you for your reply. I have disabled all add-ons in Firefox with no success. I have found that using Internet Explorer the tick box is present. So this may be the way forward.
Regards,
Sid.
IanC
Recognised Expert
Message 4 of 5
Regards,
Sid.
Mmm...it's not a "solution" that I'd be hapy with - not least because IE won't run (easily) on this PC.
Which Firefox are you using ?
Using various 3.x versions of Firefox here (on different OSs) works fine for me - the tick box is present.
Do you have anything else installed that could be eg interfering with Javascript ?
themidlander
Message 5 of 5
Same here, my tick in box isnt displayed, im fed up with having to keep signing in, windows xp, using int ex 8
                               Help please
