Message 131 of 139
Re: Logging in to email problems
I agree.
Message 132 of 139
@ssrco02 wrote:
How do I turn off notifications for this thread? Getting like Twitter now.
I could tell you but unfortunately I have been asked not to post any more messages!
Message 133 of 139
Don't panic, I found the Unsubscribe button!
Message 134 of 139
Unable to log in to webmail
Trying to access my email accounts online using https://home.bt.com/login/loginform
My main email and all sub accounts all have the same error message:
Please check you entered your username and password correctly and try again. If you need help remembering your username or password you can use the links below.
I am using the correct passwords, and all email accounts are working fine  in Thunderbird client
Anyone know what the problem could be ?
Message 135 of 139
Re: Unable to log in to webmail
First thing to try is clearing your browsers history and cookies. If that does not work try another browser.
If you have a VPN try turning it off and if you have BT Web advisor try turning it off.
It might also be worth reading through the other thread about this problem.
https://community.bt.com/t5/Email/Logging-in-to-email-problems/td-p/2047703
Message 136 of 139
RESOLVED!
Turns out it is a problem with the MacAfee Web Adviser extension. Ironically, this is a feature provided by BT so you'd expect it to be compatible!
Turing off MacAfee WebAdviser in Tools > Add Ons > Manage Extensions solved the problem
Message 137 of 139
@gg30340 Thanks for your advice. I had already fixed this before reading your post
Message 138 of 139
@MartinRowe57 wrote:
RESOLVED!
Turns out it is a problem with the MacAfee Web Adviser extension. Ironically, this is a feature provided by BT so you'd expect it to be compatible! No, because it is a McAfee product rebadged for BT I would expect it to cause problems.
Message 139 of 139
I have never had MacAfee WebAdviser... Refreshing Firefox worked for me and two of my friends.
