Message 81 of 139
Re: Logging in to email problems
Same issue here, if I try to logon using Firefox then cannot access emails, but if I use Chrome then no issues. Also no issues on Iphone.
Message 82 of 139
I posted this way back on page 7 of this thread, it seems one one has tried it yet.
I have sorted the problem out by refreshing Firefox, just open Firefox and click on help at the top of the page > Troubleshooting information > Refresh Firefox,  this should work but you may have to reinstall Add-ons.
Message 83 of 139
I will try it tomorrow. Thanks.
Message 84 of 139
thanks for this, after two days of changing everything, passwords, clearing cache, bookmarks etc your suggestion has worked. thanks again
Message 85 of 139
On further thinking about this it would then appear it is fault with Firefox and nothing whatsoever to do with BT?
Message 86 of 139
I knew two days ago it was a Firefox problem, it was obvious as other browsers weren't affected. I'm surprised that other people who use this site have not tried my suggested fix, it worked for me and two of my friends.
Message 87 of 139
It's not a Firefox problem.  It's a BT problem.  Caused by their update.
Message 88 of 139
You are wrong, it's nothing to do with BT, the only people I know who had the problem are Firefox users.
Message 89 of 139
Hello Roadrunner
Have just tried your recommendation and it has worked thank you, keeping fingers crossed that is going to be it.
Message 90 of 139
Either McAfee Web advisor or firefox would have been updated to make it a " firefox problem" or the BT  interface has been changed. As far as I can ascertain Firefox has not been updated.
BT supplies Mcafee web advisor and the Email server, I would suggest that BT needs to examine whether either of these have been updated.
This "fault" also impacts access to manage your BT account via BT.com
McAfee web advisor being disabled during login is a work around, but it may take several attempts to achieve a succesful login.
