Message 1 of 5
Login details for a third party router
If I replace my Home Hub 5 on BT Infinity with a third party router, what login details should I use? Some posts, which are now almost 5 years old, suggest that they should be:
bthomehub@btbroadband.com with a password either blank or “BT”.
However, the “Helpdesk” page of the Home Hub 5 itself states that the “Broadband username” is:
[my landline number]@btbroadband.com with no evidence of a password.
Which should I use?
4 REPLIES 4
Message 2 of 5
Re: Login details for a third party router
that login for 3rd party router still applies
Message 3 of 5
Many thanks for your very prompt response.
Message 4 of 5
Are these broadband login's still the same? Just moved to full fibre and will be using a 3rd party router.
Message 5 of 5
