Trying to get into My Account on McAfee / BT Virus Protect but it asks for my email and password details. To my knowledge I have never created an account and cannot find anywhere to do so. Any ideas?
Solved! Go to Solution.
Hi @Osprey31 and thanks for posting.
Have you managed to get this sorted? Have you tried your BTiD log in details (if you have one)?
Cheers
David
Hi David I did try my BTID and it didn't work (I changed the password in 2015 so that may have been the reason it didn't work). Now I can't remember how I got to the login page!
Hi @Osprey31 Thanks for checking that and posting back.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Hi John
Problem now solved, early this morning whilst watching the cricket! Thanks to all for your assistance / thoughts.
Sorry, I see this was a while ago now, but can you remember how you did it please?
Thanking you
Hi @Sezzer, welcome to the community and thanks for posting, can you try uninstalling the virus protect software then install it following the below steps.
We recommend that you only have one version of security software on your computer. BT Virus Protect will usually detect your existing security software as part of the installation process. It will either ask you to uninstall it or do it for you.
Good evening I have the same problem.
I have been using bt virus protect for years and i have always been using the find your phone feature with no problem.
But for some reasons after logging in to My BT then going to bt virus protect all devices page which has tabs each device that is registered - it now asks for an additional user name and password or an option for mobile phone number and pin number.
I have tried using My bt login details but it finds it invalid. Also tried phone number and pin and I know these details on 6 different devices and it doesn't accept. Next I have also tried to go through the forgot password section and I don't receive any emails. I have called Bt and they have told me they do not know the problem and how to solve and in turn asked me to contact Mcfee. Mcfee have told me they don't deal with BT customers and to cont BT again. Please help thank you
Hi how did you solve the problem.
Thank you
Try posting on the McAfee forum. Don't mention it is the BT version you have.
