NAubin
Message 1 of 1
Looking for a handset with certain features...
Hi,
I want to replace my cordless DECT handsets (currently BT XC 200) with a new set. I have some specific requirements and having trouble searching for the specifications via shopping sites.
What I am looking for:
- 2 cordless handsets, or 1 fixed handset and 1 cordless
- DECT
- Need hands free and/or an ability to connect some sort of headset
- Dont need answer machine
- Need the ability to store long phone numbers and pauses into the phone. Looking for more than 35 numbers/codes. My XC200 does this - but the amount of numbers you can store is limited to about 20.
Its this last requirement that is tricky to search for as it is not specified on most websites.
Any help would be very much appreciated.
Neil
