forestfield
Message 1 of 3
Loop disconnect (aka pulse dial) and 21cn exchanges?
Can anyone confirm/deny that 21cn exchanges (in this case 01293) support pulse dialling?   I've just tried anold rotary dial trimphone and get 'the number is not recognized'.   If it doesn't, I'll just use it for incoming calls.
-- Paul --
2 REPLIES 2
Moderator-Retired
Message 2 of 3
Re: Loop disconnect (aka pulse dial) and 21cn exchanges?
As far as I am aware, 21CN does support pulse dialling although my knowledge on the topic is quite poor so it may require input from others should you require more information.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Message 3 of 3
Take a look at this public document, it covers everything you need to know. Look at C19 for your answer.
https://www.btwholesale.com/pages/downloads/21_Century_Network_Community/switched_on_QA_document_ver...
