Message 1 of 3
Losing connection twice a day, same time each day...
Hi everyone,
Not sure if I'm the only one with this issue, but for the last 2-3 weeks or so my router loses connection twice a day at around the same times: 9:00-9:30 am and 7:00-7:30 pm. It re-establishes connection on its own and only takes about 2 minutes, but it is annoying nonetheless.
I have tried resetting the router, power etc but still occurs. Any advice?
2 REPLIES 2
Message 2 of 3
Re: Losing connection twice a day, same time each day...
do you have any line noise  dial 17070 option 2  should be silent and best with corded phone
with drops at regular times it suggests something in your home causing interference maybe central heating boiler switching on/off causing arcing or some other electrical device
Message 3 of 3
Many thanks for your suggestion. I had an electricity usage meter next to the modem which seems to have interfered with it. Removing it has solved the problem!
Cheers
