Message 1 of 48
Loss of speed on download
Line state Connected Connection time 0 days, 0:11:52 Downstream 768 Kbps Upstream 448 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.1 Latency type Interleaved Noise margin (Down/Up) 14.4 dB / 18.0 dB Line attenuation (Down/Up) 51.0 dB / 29.0 dB Output power (Down/Up) 17.5 dBm / 12.3 dBm Loss of Framing (Local) 0 Loss of Signal (Local) 0 Loss of Power (Local) 0 FEC Errors (Down/Up) 4 / 0 CRC Errors (Down/Up) 0 / 2147480000 HEC Errors (Down/Up) nil / 0 Error Seconds (Local) 0
Bt engineer came twice, 1st attemp re wired the house connection go 1.95 download
2nd engineer came yesterday replaced home hub got downstream to 3.95
today it dropped to 0.3 then up to 0.13 downstream
ping test all over the place was between 35 to 57
then whent up to 635 then 325 ping
does any one at BT realy CARE
47 REPLIES 47
Message 2 of 48
Re: Loss of speed on download
can you run btspeedtester and post the results please
Message 3 of 48
Bt speedtester:
 Profile 3756
IP profile 135
but this changes every day no sability on the line
Message 4 of 48
just lost my connection again, so who is pulling the strings, phoned tech help they keep making promises that dont happen, I am about to cancel my Bt broadband and send a complaint to OFCOM< I am paying £30 per Month for a service that is not reliable, or  stable.
Message 5 of 48
are you connected to the master or test socket or somewhere else?  have you tried the quiet line test dial 17070 option 2 should hear nothing and best done with a corded phone.
the stats you posted at the outset showed your noise margin at 14.4 is high as normal is 6 suggesting a possible noise problem on your line   with your 51 attenuation you should be able to get about 4/4.5mb on a good line with no noise problem
Message 6 of 48
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
94 Kbps
0 Kbps250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 94 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :3776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Message 7 of 48
due to all the resets because of the work done your profile has dropped to rock bottom 135 instead of the correct 3000.  if you can maintain connectio 24/7 for 3/5 days maybe sooner your profile should return to normal
Message 8 of 48
FAQ
Results Image not loaded
<script type="text/javascript"></script> Test1 comprises of Best Effort Test: -provides background information.
Download Speed
116 Kbps
0 Kbps250 Kbps
Download speedachieved during the test was - 116 Kbps
still no improvement, have done speedtest showing fluctuating ping test up 685, do you not agree that IP profile is little better than the old dial up internet speed,I have had enough with Bt intend to send a formal complaint to OFCOM as bt have failed get get back to me when they do they phone from INDIA and we get cut off so I will be off to a better provider soon
Message 9 of 48
your profile is still 135 and as I said before it can take 3/5 days of being connected 24/7 for your profile to come back to normal.  you can read more about it here  http://www.kitz.co.uk/adsl/IPprofile.htm
have you been connected 24/7 since yesterday?
Message 10 of 48
Line stateConnected
Connection time0 days, 21:28:00
Downstream3,776 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)13.1 dB / 20.0 dB
Line attenuation (Down/Up)50.0 dB / 28.0 dB
Output power (Down/Up)19.0 dBm / 12.1 dBm
Loss of Framing (Local)39
Loss of Signal (Local)4
Loss of Power (Local)0
FEC Errors (Down/Up)15042 / 7
CRC Errors (Down/Up)183 / 2147480000
HEC Errors (Down/Up)nil / 7
Error Seconds (Local)91
