Message 41 of 48
Re: Loss of speed on download
Line state Connected Connection time 0 days, 20:49:09 Downstream 1,984 Kbps Upstream 448 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.1 Latency type Interleaved Noise margin (Down/Up) 23.4 dB / 20.0 dB Line attenuation (Down/Up) 51.0 dB / 29.0 dB Output power (Down/Up) 18.6 dBm / 12.3 dBm Loss of Framing (Local) 297 Loss of Signal (Local) 131 Loss of Power (Local) 0 FEC Errors (Down/Up) 108207 / 2 CRC Errors (Down/Up) 86 / 2147480000 HEC Errors (Down/Up) nil / 2 Error Seconds (Local) 424
3 engineer tested the phone line he says no problem, but is now checking at the exchange end
still getting High ping tests of 543, bt speedtest was 75kbps
noise levels have remained high at 23.4 when I was told that it should be lower still waiting to hear from the broadband tech help side
Message 42 of 48
Ps No one can explain to me why I keep losing my broadband connection so that each day I loose any stabilisation period
this is now getting behind a joke seriously considering cancelling with BT
Message 43 of 48
just keep contacting mod StephanieG as I can't see anything you can actually do that you haven't done already
Message 44 of 48
Test1 comprises of Best Effort Test: -provides background information. Download Speed 114 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 114 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :5440 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps
Tech department have just reset my hub above are the results of a bt speed test
but on speedtest.net the ping rate is still high at 253
Line stateConnected
Connection time0 days, 0:22:14
Downstream5,440 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)5.6 dB / 20.0 dB
Line attenuation (Down/Up)49.0 dB / 28.0 dB
Output power (Down/Up)19.6 dBm / 12.2 dBm
Loss of Framing (Local)308
Loss of Signal (Local)132
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)24 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)455
Message 45 of 48
your connection speed is as high as I have seen at 5440 and your noise margin is down normal at 5.6.  you have changed to 'fast' instead of interleaved but not sure why.  Be interesting to see if you can maintain connection and get your profile up from rock bottom 135
Message 46 of 48
Download Speed 48 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 48 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :4608 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault. this bt speed test asking me to proceed to test 3 but I cannot re set log in as they ask
as you can see the connection rate has dropped from last night ip profile still 135 again on speedtest.net high ping test at 335
Message 47 of 48
Hi I agree with imjolly's earlier comments you need the mods intervention on this one as your line has stability issues
Message 48 of 48
your are never going to get away from 135 profile without mod help.  you need to contact the mods or StephanieG.
