Message 11 of 48
Re: Loss of speed on download
your noise margin is a bit high at 13.1 due to the resets/disconnections as normal is about 6.  at present you need to stay connected 24/7 until your profile rises to 3000 which normally takes 3/5 days.
once you have your profile back you could try the test socket and see f your connection will get better as with an attenuation of 50 you could get a connection speed of about 4.8mb on a good line with no noise problems
Message 12 of 48
Line state Connected Connection time 1 day, 13:44:35 Downstream 3,776 Kbps Upstream 448 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.1 Latency type Interleaved Noise margin (Down/Up) 12.9 dB / 20.0 dB Line attenuation (Down/Up) 50.0 dB / 28.0 dB Output power (Down/Up) 19.0 dBm / 12.1 dBm Loss of Framing (Local) 39 Loss of Signal (Local) 4 Loss of Power (Local) 0 FEC Errors (Down/Up) 19777 / 9 CRC Errors (Down/Up) 226 / 2147480000 HEC Errors (Down/Up) nil / 9 Error Seconds (Local) 122
Message 13 of 48
you can check btspeedtester to see if your profile has increased but I expect it will take the 3/5 days 24/7 connected before any increase - you halfway there roughly
Message 14 of 48
Connection rate getting worse: typical ping tests have been 93, 465, 869 download now down to 0.07
surely this is not right at one point the download hit 0.04 slower than dial up.
tried bt speedtester but could not procced to test3 as i cannot change my connection as described
speedtest@speedtest_domain how do I procced on this test
Message 15 of 48
there is no point going to 3 as it rarely works if at all
the first 2 test are sufficient
Message 16 of 48
This Test comprises of Best Effort Test: -provides background information. Download Speed 16 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 16 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :3776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps web pages now failing to load this is nonsence
Message 17 of 48
Line state Connected Connection time 2 days, 11:38:26 Downstream 3,776 Kbps Upstream 448 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.1 Latency type Interleaved Noise margin (Down/Up) 12.3 dB / 20.0 dB Line attenuation (Down/Up) 50.0 dB / 28.0 dB Output power (Down/Up) 19.0 dBm / 12.1 dBm Loss of Framing (Local) 39 Loss of Signal (Local) 4 Loss of Power (Local) 0 FEC Errors (Down/Up) 30778 / 9 CRC Errors (Down/Up) 347 / 2147480000 HEC Errors (Down/Up) nil / 9 Error Seconds (Local) 205
Message 18 of 48
you have a 3.7mb connection but your profile is still at rock bottom 135.
normally that should rise on your current speed to 3000 in 3/5 days stable connection which you have not reached yet.
if it does not change say after at least 3 days stable then contact the mods  http://bt.custhelp.com/app/contact_email/c/4951
it may take mods a few days to get back to you and if profile has not risen by then and provided connection still stable then mods will fix it for you
Message 19 of 48
Line stateConnected
Connection time0 days, 0:15:05
Downstream3,552 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)16.3 dB / 20.0 dB
Line attenuation (Down/Up)49.0 dB / 28.0 dB
Output power (Down/Up)19.1 dBm / 12.2 dBm
Loss of Framing (Local)42
Loss of Signal (Local)5
Loss of Power (Local)0
FEC Errors (Down/Up)637 / 0
CRC Errors (Down/Up)13 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)304
loss of connection again did get 2.41 download on speed test, but profile also keeps falling
Message 20 of 48
have you run btspeedtester to see if your profile has changed to 3000 from rock bottom 135?
