Message 31 of 48
Re: Loss of speed on download
just read through all the post and see I asked a couple of time about if you were connected to the master or test socket or somewhere else but you never replied.  also do you have extension sockets in other rooms in your home?
Message 32 of 48
The engineer came 2 weeks ago and re wired from outside to a new box in the house with the in built filter box I dont have any other extensions
Message 33 of 48
ok that's great so connected to that with no extension cable? just rules out something else
Message 34 of 48
Test1 comprises of Best Effort Test: -provides background information. Download Speed 84 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 84 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :1824 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps
we are back to 135
Message 35 of 48
you have the mod StephanieG looking into your problem so just need to wait until mods come back to you
Message 36 of 48
Line state Connected Connection time 0 days, 0:14:41 Downstream 256 Kbps Upstream 448 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.1 Latency type Interleaved Noise margin (Down/Up) 32.9 dB / 12.0 dB Line attenuation (Down/Up) 50.0 dB / 28.5 dB Output power (Down/Up) 14.9 dBm / 12.3 dBm Loss of Framing (Local) 409 Loss of Signal (Local) 147 Loss of Power (Local) 0 FEC Errors (Down/Up) 16 / 0 CRC Errors (Down/Up) 0 / 2147480000 HEC Errors (Down/Up) nil / 0 Error Seconds (Local) 1024
Further lost connection today download now 256 have 3 engineer coming on Friday afternoon
Message 37 of 48
FAQ This Test comprises of Best Effort Test: -provides background information. Download Speed 31 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 31 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :3712 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault. If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results. Please visit FAQ section
Message 38 of 48
your connection speed has come back up to 3712 but your profile is still rock bottom following the previous very low connection speed.  not a lot you can do but wait on engineer coming on friday
Message 39 of 48
This Test comprises of Best Effort Test: -provides background information. Download Speed 43 Kbps 0 Kbps 250 Kbps Max Achievable Speed Download speedachieved during the test was - 43 Kbps For your connection, the acceptable range of speeds is 50-250 Kbps. Additional Information: Your DSL Connection Rate :1984 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 135 Kbps conection rate dropped again 43kbps is slower than the old dial up internet
Message 40 of 48
another reset and a drop in speed again - still engineer should be there tomorrow
