Ningmaster
Message 1 of 9
Lossiemouth
Hi, The Lossiemouth exchange shows Accepting Orders but my cabinet shows nothing, no date... so id assume its not being considered or done, however several people i know (one has the new box outside house) also cant place orders.
Soooo question is has it been enabled or not...  P.S if anyone can check my cabinet number shows as 6 On Lossimouth Exchange
Thanks Then.
8 REPLIES 8
Message 2 of 9
Re: Lossiemouth
Just enter your phone number https://www.btwholesale.com/includes/adsl/main.html
Ningmaster
Message 3 of 9
Re: Lossiemouth
Ah yes, i have used that before, and all the people i talk to have also tried it. nothing comes up.. no date etc.. yet shows accepting orders on the where and when, just wondering if there is a mistake on the where and when site thats all, as it would seem no-one has had theirs switched on..
Guru
Guru
Message 4 of 9
Re: Lossiemouth
Hi Ningmaster,
Below are the FTTC cabinets in the IV31 postcode area (be that already installed & FTTC available and those that are still either being installed/commissioned or planned to be installed)
  Cabinet (PCP) Number Exchange FTTC Status
IV316BX 1 LOSSIEMOUTH  Still being Installed/Commissioned
IV316ED 2 LOSSIEMOUTH  Still being Installed/Commissioned
IV316LP 3 LOSSIEMOUTH  Still being Installed/Commissioned
IV316HY 4 LOSSIEMOUTH  Available
IV316RL 5 LOSSIEMOUTH  Available
IV316AL 7 LOSSIEMOUTH  Still being Installed/Commissioned
IV316QT 8 LOSSIEMOUTH  Still being Installed/Commissioned
IV316AL 9 LOSSIEMOUTH  Still being Installed/Commissioned
*** Number of postcodes analysed: 259 | Out of : 259 | Number of hits : 7 ***
As you can see some of the DSLAM cabinets are already live on the LOSSIEMOUTH  exchange.
Hope that helps
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 5 of 9
Re: Lossiemouth
@jac_95
there is no cab 6 which is the important cab
Guru
Guru
Message 6 of 9
Re: Lossiemouth
Ye looks like you're right imjolly. Doesn't look like there is any activity on cab 6 yet.
Try a Search
Ningmaster
Message 7 of 9
Re: Lossiemouth
Ah no cabinet 6, seems right.. postcode would be IV316SD which is RAF Lossiemouth, ive seen the box and its not updated, which is annoyind as the amount of openreach engineers parked next to it everyday is annoying..
Dont suppose there are any further notes on postcode search pr the cabinet then...
Message 8 of 9
Re: Lossiemouth
If the cabinet is on MOD property that could be the cause of the problem getting permission for a variety of contractors that are needed for the cabinet install
Message 9 of 9
Re: Lossiemouth
the list jac_95 produced and the information from the wholesale checker are as good you can get.  if cab on RAF base that would explain why it's missing fromlist and why not upgraded
