Message 1 of 25
Lost a further 10mbps hh5a
After the supposed fix, I've lost another 10 meg.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34621340
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 17/01/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:05:34
6. Data rate:3696 / 29998
7. Maximum data rate:33252 / 104394
8. Noise margin:28.2 / 23.8
9. Line attenuation:9.8 / 9.6
10. Signal attenuation:9.6 / 9.6
11. Data sent/received:13.1 MB / 486.1 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
24 REPLIES 24
Distinguished Guru
Message 2 of 25
Re: Lost a further 10mbps hh5a
Looks like DLM has capped your speed. Why is the uptime only 5 minutes?
If not, I'll try again 🙂
Message 3 of 25
Hi Ray,
Just re-booted it.
Have left it on overnight for night fixes, but no joy.
peter
Distinguished Guru
Message 4 of 25
So is it still unstable?
Message 5 of 25
Yes... plenty of unable to connect to network.
Distinguished Guru
Message 6 of 25
Sorry, when do you get that message?
Message 7 of 25
Like when I re-load a page.
It's mainly taking an aeon to connect to a new site.
Distinguished Guru
Message 8 of 25
Is this wired or wireless?
Message 9 of 25
Wired.
Distinguished Guru
Message 10 of 25
I think you have a line fault and need an engineer visit to fix it. Either that, or your Homehub has been broken by the firmware update and needs replacing. Either way, you need to call the helpdesk and report the problem.
