Message 11 of 25
Re: Lost a further 10mbps hh5a
OK... thanks Ray.
Message 12 of 25
Just borrowed an Asus DSL-AC68U and slung it on for giggles.
Seems like pages were loading a great deal faster, but speed test shows the same capping.
It was worth a punt.
Distinguished Guru
Message 13 of 25
DLM takes about 2 weeks to remove the capping
If not, I'll try again 🙂
Message 14 of 25
Sorry Ray, but what is DLM?
I was in touch with BT and they say they have not identified a fault, but can see that the line drops many times a day.
They say they will be monitoring my connection for a couple of days and then give me a call.
Would you suggest the hh5 go back on?
Distinguished Guru
Message 15 of 25
Dynamic Line Management keeps an eye on your line for errors and disconnetions. If it detects any, it changes the line parameters to try and fix them.
DLM doesn't care what modem you use.
Message 16 of 25
Thank you Ray, in Spanish.
Message 17 of 25
Message 18 of 25
Thanks gg
Message 19 of 25
Lost a few more overnight... down to 25/3, from 78/20. Oh the misery.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34621340
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 17/01/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 05:39:44
6. Data rate:3199 / 27400
7. Maximum data rate:33575 / 104223
8. Noise margin:29.5 / 24.8
9. Line attenuation:9.8 / 9.6
10. Signal attenuation:9.6 / 9.6
11. Data sent/received:93.1 MB / 2.4 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
Message 20 of 25
This must be the record.
5. DSL uptime:0 days, 01:06:20
6. Data rate:1296 / 16495
7. Maximum data rate:28275 / 104742
8. Noise margin:31.0 / 30.5
9. Line attenuation:8.9 / 9.6
10. Signal attenuation:8.3 / 9.6
11. Data sent/received:94.4 MB / 3.2 GB
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:soppybollox
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:soppybollox5
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:62:2c:55:bc:ae
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
