Message 21 of 25
Re: This must be the record.
Just received a replacement home hub 5A, with the older firmware 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown.
Here's hoping my speeds begin to creep up.
Message 22 of 25
That didn't cure it... I've set a new record low. Time for an engineer I think.
1. Product name:BT Home Hub
2. Serial number:+076272+NQ43853592
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 01:46:37
6. Data rate:798 / 14998
7. Maximum data rate:17766 / 103514
8. Noise margin:31.0 / 30.9
9. Line attenuation:0.0 / 9.8
10. Signal attenuation:0.0 / 9.8
11. Data sent/received:69.8 MB / 2.0 GB
12. Broadband username:bthomehub@btbroadband.com
Distinguished Guru
Message 23 of 25
DLM takes 2 weeks to recover typically.
An engineer should be able to reset your DLM there and then, you shouldn't have to wait.
If not, I'll try again 🙂
Message 24 of 25
Thanks Ray, good to know.
Engineer comes on Friday.
Message 25 of 25
No show on Friday, but just left me with a healthy connection.
Couldn't find a line fault... nothing wrong with installation, cables all good... so couldn't pin i down.
Reset DLM and happy for now.
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 04/03/15
5. DSL uptime:0 days, 00:43:22
6. Data rate:19999 / 79995
7. Maximum data rate:30594 / 101675
8. Noise margin:15.2 / 12.0
9. Line attenuation:9.6 / 9.9
10. Signal attenuation:9.7 / 9.9
11. Data sent/received:4.2 MB / 122.1 MB
13. BT Wi-fi:Yes
