taff150
Message 11 of 28
Re: Low Broadband Speed
Just had a look. they are wired in series. There are 2 orange wires connected to terminal 3. One comes from the otside box.
Message 12 of 28
so there are 3 wires normally white/blue and blue/white on terminals 2 & 5 and sometimes the bellwire on terminal 3.  if that is the case then normally it is suggested to remove the orange bellwire on terminal 3 on all sockets as it can cause noise on your line
gouledw
Recognised Expert
Message 13 of 28
You could try removing the orange bell wire from terminal 3 outside too, but I would do as IMJ suggested and do the internal ones first.
taff150
Message 14 of 28
I have disconnected the wires on terminal 3
gouledw
Recognised Expert
Message 15 of 28
Stats any better? Can you repost them please.
Message 16 of 28
has that made any change to your connection speed or noise margin?
taff150
Message 17 of 28
thank you ihave already disconnected the bell wire on termial 3
taff150
Message 18 of 28
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
640 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 640 Kbps
For your connection, the acceptable range of speeds is 400-1000 Kbps.
Additional Information:
Your DSL Connection Rate :800 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 705 Kbps
2. Upstream Test: -provides background information.
Upload Speed
319 Kbps
0 Kbps 448 Kbps
>Upload speed achieved during the test was - 319 Kbps
Upstream Rate IP profile on your line is - 448 Kbps
Message 19 of 28
disappointing as I was hoping for a change but these stats appear just as before - what about the router adsl stats
taff150
Message 20 of 28
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 4 days, 21:15:11
Downstream: 800 Kbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 6.2 dB / 14.0 dB
Line attenuation (Down/Up): 62.6 dB / 31.5 dB
Output power (Down/Up): 14.7 dBm / 12.6 dBm
FEC Events (Down/Up): 20320 / 4182
CRC Events (Down/Up): 170 / 235
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 656 / 173
Error Seconds (Local/Remote): 440588 / 9467
